Bertie 314 #1 Posted June 25, 2017 (edited) Could anyone post a pic of the (if any) tail lights you have fitted original or modified as part of the area mine will be on means I will have to road register the C121 once it's running.... Edited June 25, 2017 by Bertie Share this post Link to post Share on other sites
pfrederi 21,177 #3 Posted June 25, 2017 (edited) Are there reflectors on your rear fender like picture?? If there are and you pry them off there will probably be holes you can use to mount standard (in the US anyway) truck marker lights like second picture (regular or LED are widely available. EDIT Added a third picture and another setup Edited June 25, 2017 by pfrederi 1 Share this post Link to post Share on other sites
"D"- Man 827 #4 Posted June 25, 2017 I had fenders from my 18 Automatic widened to accommodate 6 tail lights {3 per side} with reverse lights in the 2 middle lenses. Only 4 of the 6 are shown in this picture. I am wanting to convert to LEDs instead of the incandescent bulbs that are in the base. 1 Share this post Link to post Share on other sites
Bertie 314 #6 Posted June 25, 2017 1 hour ago, "D"- Man said: I had fenders from my 18 Automatic widened to accommodate 6 tail lights {3 per side} with reverse lights in the 2 middle lenses. Only 4 of the 6 are shown in this picture. I am wanting to convert to LEDs instead of the incandescent bulbs that are in the base. Never mind the tail lights..... Are they tail pipes 😎 2 hours ago, pfrederi said: Are there reflectors on your rear fender like picture?? If there are and you pry them off there will probably be holes you can use to mount standard (in the US anyway) truck marker lights like second picture (regular or LED are widely available. EDIT Added a third picture and another setup Thanks for this 👍 1 Share this post Link to post Share on other sites
"D"- Man 827 #7 Posted June 25, 2017 Bertie, no the "tail pipes" are just for looks. These are chome exhaust tips intended for a car. Share this post Link to post Share on other sites
Bertie 314 #8 Posted June 25, 2017 26 minutes ago, "D"- Man said: Bertie, no the "tail pipes" are just for looks. These are chome exhaust tips intended for a car. Phew 😂 2 Share this post Link to post Share on other sites
edgro 680 #9 Posted October 9, 2017 recently upgraded lights on plow tractor. Rear lights I got at work, are Maxxis brand. The side mounted flashing lights came from that auction site 3 Share this post Link to post Share on other sites
