WheelHorseJunkie71 2 #1 Posted June 24, 2017 (edited) Searching around here and there I'm seeing numerous responses regarding what ignition switch I need to replace the one on my 8hp Kohler, Commando 8. Any suggestions? Mine wasn't present when I got it, and in it's place is a crumbling push button switch minus the harness. Thanks Aaron Edited June 24, 2017 by WheelHorseJunkie71 Share this post Link to post Share on other sites
new2horses 287 #2 Posted June 24, 2017 I have the Cole-Hersee switch that would have been original equipment on your tractor in stock. $40.00 shipped to your door. PM for more info. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #3 Posted June 24, 2017 You could use a more common and less expensive switch if you add a solenoid. If it were mine and I wanted to stick with the expensive original switch I would still add a solenoid to extend the life of the new switch. Garry 1 Share this post Link to post Share on other sites
