By
RainbowMeatballs
						Following the death of my 520H's fuel pump, I bought a low-pressure electric pump. The problem is, I know almost nothing about electrical systems, and I am wondering where to hook up the pump. I am thinking that I could use the pink line coming from the A terminal, but I'm not absolutely sure. I was also wondering if I could attach it with ring hooks to one of the meters. (piggy-backing) I'm not sure of the amps this uses, but it seems to have 14 gauge wire. To be safe, would adding a 20 amp fuse screw up the meters if I switched it in the place the 10 amp? This is the pump: Amazon
I have an inline fuse holder if my ideas have been completely wrong.
