Countdown To Christmas!
WHC-125
Pics of my new GT 14
WHC-125
Here are some pics of my new GT 14. I will get pics of the deck and plow soon.
And does anyone know how to repair the gas tank on one of these. :thumbs:
baerpath
Hey that looks familiar I have a pair of them :thumbs: I like the 69's. Nice find Chris
Duane
Cody
Nice find :thumbs: it looks real straight. All of the gas tankes on my gt-14's have a spot that is melted a little but not completly through.
BairleaFarm
Clean looking tractor
Teddy da Bear
Take the tank to a plastic welder.
It is a specialized kind of trade.
You can do it yourself as I have seen
kits and welding rod at Harbor Freight.
But I have a feeling it is the kind of thing
you can mess up really easy.
KyBlue
Eastwood.com sells kits to weld plastic too...
WHC-125
What if I was to sand the spot down and JB weld it because I was told it doesnt leak but I want to fix it to make sure :thumbs:
KyBlue
I think Id Find a 2 part Epoxy made for plastic... rather than JB Weld.. by the way...Really clean looking starting point!!
Buzz
I agree. Do a Google search for "plastic epoxy" and you'll be amazed on how many products are out there. It's a lot easier to repair it correctly now while it's apart. :thumbs: Keep your pictures coming.
Teddy da Bear
I agree with 4star too.
Just hope there is not some chemical reaction between
2 different materials.
Perhaps you can try a small spot first to see if it works
and is compatable.
Until I got my second GT-14, I did not know the
muffler heat shield was missing on the first one. I am not refering
to the metal shield in between the tank and engine. My second
one has a shield that separates the tank and the can-muffler.
But I cannot speak for the 69 model year as mine are 70's.
TJ
Nice looking tractor. :thumbs:
WHC-125
I found a 16 horse Kohler that I am going to pick up tomorrow afternoon :thumbs: :banana:
Teddy da Bear
Awww.....now I am not the only one with a 16hp....GT-14! :thumbs:
WHC-125
Teddy da Bear,
I was thinking of you when I was on the phone with the guy :thumbs:
The one that I am getting is out of a C-160 though so its a K341
Brrly1
Hey Teddy You weren't the only GT16 owner, My Tri-GT is 16 hp also, plus I also have another 16 hp just a waitin' to get installed in a 69 GT14 See Ya Bye Burly
:horseplay: :horseplay: :horseplay: :horseplay: :horseplay: :horseplay: :horseplay:
CHARGER9AUTO
Burly, I have my '69 GT-14 the correct 14 HP motor knocks I have another K-321 out of a Bronco 14 it ran when I took out of the tractor . or put the K-341 into the GT this Spring . Ben.....
Teddy da Bear
Burly I am still waiting for you to bring home that
long promised FEL... :whistle: And GT-14's were born with
4 legs.....that thing you got there must be an old farmall.. :whistle:
WHC-125....hey...at least somebody thinks of da Bear!
I hope your 16hp kohler fits better than mine. Mine is the
newer magnum series and p.o. "bent" the hood out to fit
around the motor shroud. I think my frame or motor mounts
could be slotted and the motor "shifted" over and the hood
would fit properly then.
Look before you leap when mounting that motor! :thumbs:
Brrly1
Patience is a virtue. At least thats what I have been told. Mom told me so its got to be true. John :thumbs:
WHC-125
Aren't 14 hp and 16 hp Kohler K series the same size just a different bore :thumbs:
Brrly1
Hey Chris, If you install a 16 hp in your GT I went directly back to the same mount holes as the 14 hp. You don't need to drill anything as far as I know. They are the same block, yes, K series. Post some more pictures as you go. Good Luck
Burly :horseplay: :horseplay: :horseplay: :horseplay: :horseplay: :horseplay:
WheelHorse_of_course
Seal-all is gasoline resistant and works on metal gas tanks (my brother used to have a lot of old trucks and found this stuff really works).
This is good stuff, it is sort of a industrial Duco cement!
:whistle: :thumbs:
WHC-125
I cant get the motor tonight because its snowing pretty bad and the guy that has it is about 30 minutes away :whistle: So I am going to have to wait till the weekend :thumbs:
Burly,
Dont worry I will be posting alot of pics :dunno:
Rolf,
It is a plastic gas tank that was melted :whistle:
Coadster32
Home Depot has alot of epoxy's to chose from. I was like :thumbs: chosing a general 2-part myself.
WHC-125
This weekend I am going to try and get some progress on her, even drop a motor in her :thumbs:
KyBlue
Sweet!
