jim3sr 2 #1 Posted June 17, 2017 Would I be able to put a 10 hp mag on a312-8 Share this post Link to post Share on other sites
pfrederi 19,783 #2 Posted June 17, 2017 Very probably you can but the issue is probably going to be the length of the crankshaft on the PTO end. Wheel horse need a some what long crank to accommodate the PTO. Not all other users needed it. Depending on the Magnum you get your choke may work backwards. I put an M-12 on a C-81 but choke is backwards. You also will have to change the ignition switch if you 312 has a battery ignition. 1 Share this post Link to post Share on other sites
