NYJack 9 #1 Posted June 16, 2017 I have a Toro Wheel Horse Classic with the Koehler engine. My fuel pump died so I rigged up an electric one with power supplyed direct from the battery with an alligator clip I snap on the battery while using the tractor, and usually unhook it when done. So, my son will be mowing the yard this summer and the chance of him remembering to unhook the wire are slim. Therefore I would like to wire the pump wire to somewhere that is hot only when the tractor is turned on and running. Unfortunately I do not have a manual or wire diagram. Advice and help greatly appreciated! jack Share this post Link to post Share on other sites
Racinbob 13,087 #2 Posted June 16, 2017 Give us the model # of your tractor and we'll find the wiring diagram. You want it connected so it's powered with the key in the run position. Share this post Link to post Share on other sites
NYJack 9 #3 Posted June 16, 2017 Sorry, it is a 312 hydro. Share this post Link to post Share on other sites
Achto 32,260 #4 Posted June 16, 2017 49 minutes ago, NYJack said: Therefore I would like to wire the pump wire to somewhere that is hot only when the tractor is turned on and running. Unfortunately I do not have a manual or wire diagram. With a multi meter or a simple test light, probe the wires coming out of the key switch. Find a wire that is live only when the switch is in the run position. Once you locate the wire you need , connect your pump to it. 1 Share this post Link to post Share on other sites
953 nut 68,176 #5 Posted June 16, 2017 This manual will give you the wiring information you need. The "L" terminal on your ignition switch will give you key on power. Be sure to put a fuse in the line, 10 amp should do the trick. 3 Share this post Link to post Share on other sites
squonk 47,769 #6 Posted June 16, 2017 Here you go. The power hook up will be different if you have electronic ignition but everything else is the same. 2 Share this post Link to post Share on other sites
midpack 1,148 #7 Posted June 16, 2017 I tapped into the light switch wire to power a relay to run the pump straight off the battery. works just the way you need it too! 1 Share this post Link to post Share on other sites
6bg6ga 272 #8 Posted June 16, 2017 1 hour ago, midpack said: I tapped into the light switch wire to power a relay to run the pump straight off the battery. works just the way you need it too! Just a suggestion.. You should install a fuse from the battery to the fuel pump if you don't have one. I like the fact that you used a relay to control the fuel pump and didn't try to run it thru the ignition switch. Is the light switch circuit inactive when the ignition switch is in the off position? Some manufacturers have a live light circuit. I had a Yard Man that had a live light circuit that I had to remember to make sure it was turned off when I was done snow plowing. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #9 Posted June 16, 2017 This may be the model you have. I would use the R terminal on the ignition switch to control a relay powered by the battery. The pump would not work in the Start position but if you turned the key to Run for a few seconds before starting the carb would be ready to go. Garry Share this post Link to post Share on other sites
6bg6ga 272 #10 Posted June 16, 2017 7 minutes ago, gwest_ca said: This may be the model you have. I would use the R terminal on the ignition switch to control a relay powered by the battery. The pump would not work in the Start position but if you turned the key to Run for a few seconds before starting the carb would be ready to go. Garry To make things simple the pump needs to prime the carb for an easy start. Making it function in the start and the run position is the best of both worlds. Share this post Link to post Share on other sites
midpack 1,148 #11 Posted June 16, 2017 (edited) 1 hour ago, 6bg6ga said: Just a suggestion.. You should install a fuse from the battery to the fuel pump if you don't have one. I like the fact that you used a relay to control the fuel pump and didn't try to run it thru the ignition switch. Is the light switch circuit inactive when the ignition switch is in the off position? Some manufacturers have a live light circuit. I had a Yard Man that had a live light circuit that I had to remember to make sure it was turned off when I was done snow plowing. I did use a blade fuse inline for the pump, and also one off the light wire my light circuit is live in both the "start" and "run'", no power in the "off" position.with the key. I used a light probe on the wires before I chose to use that wire Edited June 16, 2017 by midpack Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #12 Posted June 16, 2017 10 hours ago, midpack said: I did use a blade fuse inline for the pump, and also one off the light wire my light circuit is live in both the "start" and "run'", no power in the "off" position.with the key. I used a light probe on the wires before I chose to use that wire Disregard the 1990 wiring then because the lights are not powered in the Start position. Garry Share this post Link to post Share on other sites
6bg6ga 272 #13 Posted June 17, 2017 23 hours ago, midpack said: I tapped into the light switch wire to power a relay to run the pump straight off the battery. works just the way you need it too! Just so I understand you correctly ... you used the light circuit to power a relay. You then came off the battery with a fused wire to the relay that will power the pump. Absolutely the right way to do it. In doing it that way you have a live circuit in start and in run. You have used a relay so you didn't burden the ignition switch. You also protected the power wire running from the battery to the relay with its own fuse. This is the BEST way to accomplish the task. This is the best example I've seen so far of using common sense instead of trying to depend on a wiring diagram that may or may not be accurate/ correct. You got it done, its done right and it cannot be improved upon. GREAT JOB!!!!!!! 1 Share this post Link to post Share on other sites
midpack 1,148 #14 Posted June 19, 2017 aww, thanks! I imagine I got most of the design from hanging around here though. I won't take all the credit 1 Share this post Link to post Share on other sites
kwalshy 258 #15 Posted October 27, 2018 After wasting my time and $ on another cheap fuel pump that was no good out of the box, I’ve decided to install a Facet 60304. I have a new 40 Amp relay, is this too large of a relay for this electric pump conversion install if I use an inline 3-5 Amp fuse? And I apologize for what might be a stupid question, but I install the fuse between battery & relay correct? Or fuse goes between relay & pump? Thank you! 1 Share this post Link to post Share on other sites
Skipper 1,792 #16 Posted October 27, 2018 (edited) Fuse directly after, and as close to the battery as you can with reason. Go for the smallest fuse you can find. That pump wont use much current Relay size is fine, and of no concern, as long you dont overload it. It can handle up to 40 A, and will work just as fine with no or very little load, which is the case here. Put your pump in a cool place, under tank level. Heat is what pumps dont like, and they don't suck good either. Edited October 27, 2018 by Skipper 1 Share this post Link to post Share on other sites
