Toasty 52 #1 Posted June 15, 2017 I bought a C1750 with a C160 parts tractor. The frame was in bad shape on the C175 and the last guy planned on swapping frames with the C160. I got both tractors for $50 and the C175 runs. I am trying to put the transmission back together to the linkage and not sure what I am missing how this was already torn all apart prior. Below are pictures of what I have done so far. If anyone has pictures of what it should be I would appreicate it! Thanks. Share this post Link to post Share on other sites
pfrederi 20,680 #2 Posted June 15, 2017 (edited) You appear to be missing the cam pin part #6127 Threaded end bolts in the hole in the cross piece the ball end goes into the plastic slider. #77 in parts picture Edited June 15, 2017 by pfrederi 2 Share this post Link to post Share on other sites
Toasty 52 #3 Posted June 15, 2017 Thanks for the quick response! Share this post Link to post Share on other sites
Searcher60 209 #4 Posted June 17, 2017 On 6/15/2017 at 3:02 PM, toasty said: Thanks for the quick response! Also, you will find that all of that friction linkage assembly is dysfunctional due to rust and corrosion. I had to completely disassembly mine to clean and unstick it. Stuck pretty good, and not easy to get apart without breaking it. It will not work properly like it is. Share this post Link to post Share on other sites
