tallen4392 71 #1 Posted June 15, 2017 Can u guys tell me what hooks to the plow and to the lift arm I just picked up this machine the plow was not on it it has the rear axle mount but nothing on the arm that lifts the plow up and down what is the correct piece that should be there thanks Share this post Link to post Share on other sites
953 nut 69,844 #2 Posted June 15, 2017 Take a look at this manual, it should answer everything. Share this post Link to post Share on other sites
tallen4392 71 #4 Posted June 15, 2017 Where can I get the lift rod I think that is what is missing there is a chain hanging under the tractor There is one on e slay for a raider 10 don't know if it is the same what's with the chain under there ???? Share this post Link to post Share on other sites
nylyon-(Admin) 9,066 #5 Posted June 15, 2017 By lift rod you mean that vertical rusty piece of metal in picture 4? You can try eBay, put in a wanted in the classifieds , check with some of our used parts vendors or check with Lowell, he may be able to do something https://wheelhorsepartsandmore.com/index.html Share this post Link to post Share on other sites
tallen4392 71 #6 Posted June 15, 2017 Do you know why the chain is there Share this post Link to post Share on other sites
SylvanLakeWH 32,709 #7 Posted June 15, 2017 19 minutes ago, tallen4392 said: Do you know why the chain is there I use the chain to lift / lower the front dozer blade on my C-105. (do not have a lift rod). Works great. Drawback is you can't apply down pressure, but I have never needed it and it performs very well on our Michigan snow (powder to slush to ice - all within the same storm usually!)... Share this post Link to post Share on other sites
