KC9KAS 4,746 #1 Posted June 13, 2017 Anyone ever swap a Tecumseh H60 on a 654 to a K181 Kohler (8 hp)? My H60 has a bad starter and doesn't want to start...Have a good K181 ready to go in if it will fit. Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted June 13, 2017 Should work fine you won't need the engine plate the tecky mounts too. 1 Share this post Link to post Share on other sites
953 nut 63,954 #3 Posted June 13, 2017 As long as the center line of the crank winds up being the same it shouldn't be any problem. 854 used the Kohler so it is bound to work. 1 Share this post Link to post Share on other sites
