hubast 2 #1 Posted June 12, 2017 Hi - I have a 1972 Wheelhorse GT14 that needs two "O" Rings on the top of the transaxle where the hydraulic lift lever for the deck attaches at on the transaxle. I took it all apart (because it was leaking there) and there is one "O" Ring of the two that looks flat on each side. The part numbers for the GT14 5070 transmission "O" rings are 972116 and 970026. Does anyone have a clue where I might obtain replacements? Thank you kindly - I appreciate -hubast 1 Share this post Link to post Share on other sites
pfrederi 19,089 #2 Posted June 12, 2017 Welcome to Red Square!! I do not have a GT14 but some one who does will be along. The flat ring is called a backer ring. My D200 uses them and I have a bunch but they are a different part number sorry. 1 Share this post Link to post Share on other sites
Aldon 4,828 #3 Posted June 12, 2017 Daveoman has chimed in on multiple threads concerning sundstrand rebuilds. In one of them he provides a seal part number for that shaft that is likely culprit if you have leak. Replace that seal would potentially resolve and make any oring which is close to correct likely work. As I see it, the oring acts more like a gasket. But UT there are more learned experienced folks who can chime in. And if you decide to go that route, replace seal on drive shaft and the other end of the shaft on other side of pump. Share this post Link to post Share on other sites
hubast 2 #4 Posted June 21, 2017 Thank you guys so much for helping - I appreciate it - Ill keep ya posted on my findings! Share this post Link to post Share on other sites
hubast 2 #5 Posted June 21, 2017 Okay, so after about a week of searching I found exact replacements and it worked! Anyone needing 972116 and 970026 O-rings for the GT14 let me know - I can get them! email me at hubast2003@comcast.net Share this post Link to post Share on other sites
