Gunman64 7 #1 Posted June 11, 2017 I have a 416 with a Onan engine, I noticed when i turn the key I hear a click but starter doesnt turn over. I have to turn key 4 or 5 times to get it to start, thats with or with out battery charger/starter hooked up. I think relay or could it be the starter? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,991 #2 Posted June 11, 2017 These diagrams will have one for the starter circuit One of these should have you covered. Garry 2 Share this post Link to post Share on other sites
JPWH 6,542 #3 Posted June 11, 2017 I would clean all terminals as a starting.point. then check for a bad component if that doesn't fix the problem. 2 Share this post Link to post Share on other sites
953 nut 64,012 #4 Posted June 11, 2017 With any electrical problem the first step is to clean inspect and tighten ALL electrical connections including grounds. If the problem persists have the battery load tested. 2 Share this post Link to post Share on other sites
squonk 45,411 #5 Posted June 11, 2017 The little wire terminal that connects to the solenoid is pretty crappy. That's a good place to check and clean. The opposite end of that wire at the relay is another corrosion magnet and was the cause of the same problem I had on my 520 2 Share this post Link to post Share on other sites
Gunman64 7 #6 Posted June 11, 2017 Thanks all for the help, i will clean all connections and go from there. I will check back in after i do it. Share this post Link to post Share on other sites
