rsmall5206 6 #1 Posted June 8, 2017 I have a c-160 frame that I am trying to mount my kohler 14 hp motor too. This motor came off of a c-120 frame that got wrecked. I have measured the frame and same length and width but none of the holes match up? Any suggestions would be great! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,839 #2 Posted June 8, 2017 You realize the two bolts on the right side come up through the frame and thread into the bottom of the motor? The left side bolts go down through the oil pan ears into the frame. Garry 1 Share this post Link to post Share on other sites
953 nut 62,983 #4 Posted June 8, 2017 If you have the C-120 frame it was bolted to you should be able to transfer the measurements from it. Share this post Link to post Share on other sites
