SRB 25 #1 Posted June 7, 2017 So I just got a 1975 Tiller, model # 7 1252. I am wanting to put it on my 1979 C 101 model 91-10k801. What all do I need to adapt the tiller to this tractor? So far I have figured out that I need the lever assembly for under the seat. It also looks like the 78'-79' models have a lift plate attached to the shroud over the times, instead of the eyebolt conected to the frame of the tiller. Any photos of this setup would be great. Thank you. Share this post Link to post Share on other sites
jsPond 51 #2 Posted June 7, 2017 I just bought the same exact tiller this spring and was going thru just what you are. Mine went onto a 2003 315-8. I too had to buy the lever assembly (bought from a forum member, great stuff!). After that I realized I needed the lift plate on the shroud. I just fabricated one out of what I had laying around. I really didn't know where to position the lift plate so I put three holes in it for adjustment and just lined it up with the cable. Works great! I can get some pics tonight. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #3 Posted June 7, 2017 Here is a parts list for what you need to end up with. Compare it to what you have. Garry Share this post Link to post Share on other sites
SRB 25 #4 Posted June 8, 2017 23 hours ago, gwest_ca said: Here is a parts list for what you need to end up with. Compare it to what you have. Garry Thank you Gary. That is very helpful. Share this post Link to post Share on other sites
SRB 25 #5 Posted June 10, 2017 On 6/7/2017 at 1:09 PM, jsPond said: I just bought the same exact tiller this spring and was going thru just what you are. Mine went onto a 2003 315-8. I too had to buy the lever assembly (bought from a forum member, great stuff!). After that I realized I needed the lift plate on the shroud. I just fabricated one out of what I had laying around. I really didn't know where to position the lift plate so I put three holes in it for adjustment and just lined it up with the cable. Works great! I can get some pics tonight. Jspond, I am sorry, I replied to you the other day and just noticed it didn't post. Thank you for the info and yes, if you could post a couple pictures for me I would greatly appreciate it. Again, thank you for your assistance. Share this post Link to post Share on other sites
jsPond 51 #6 Posted June 12, 2017 On 6/10/2017 at 0:04 AM, SRB said: Jspond, I am sorry, I replied to you the other day and just noticed it didn't post. Thank you for the info and yes, if you could post a couple pictures for me I would greatly appreciate it. Again, thank you for your assistance. No problem. Ain't computers wonderful? Anyway, here are a couple of pictures I took yesterday. It seems to me you are good everywhere except where the lift mount goes. I took a shot and it works pretty good. I just took a plate that I had laying around, bent it 90 degrees and put some holes in it. Really no need to overthink it. Good luck. Share this post Link to post Share on other sites
SRB 25 #7 Posted June 12, 2017 12 hours ago, jsPond said: No problem. Ain't computers wonderful? Anyway, here are a couple of pictures I took yesterday. It seems to me you are good everywhere except where the lift mount goes. I took a shot and it works pretty good. I just took a plate that I had laying around, bent it 90 degrees and put some holes in it. Really no need to overthink it. Good luck. jsPond, thanks for the photos. Share this post Link to post Share on other sites
