Mikey the Monkey 701 #1 Posted June 4, 2017 Hay experts, what's the little button thing on the bottom of the bowl of a carter model n carb? Share this post Link to post Share on other sites
rmaynard 16,840 #2 Posted June 4, 2017 The little spring-loaded button is a drain. It was used to remove old gas from the bowl. Share this post Link to post Share on other sites
Mikey the Monkey 701 #3 Posted June 4, 2017 Well thank you sir. I just started my first Wheel Horse resto on a 701. Is there supposed to be a spring in there? Did not find one when I took it apart 1 Share this post Link to post Share on other sites
rmaynard 16,840 #4 Posted June 4, 2017 The older Carter N's had a flat metal spring, button, and a rubber washer. This is the spring. Since the drain can be a problem with leakage, I just replace the bowl with a solid one. 3 Share this post Link to post Share on other sites
Mikey the Monkey 701 #5 Posted June 4, 2017 OK. My flat spring is rusted and broken. Where would a good place to find a solid bowl be other than a parts machine I don't have? Share this post Link to post Share on other sites
rmaynard 16,840 #6 Posted June 4, 2017 (edited) eBay, Amazon, and lots of other places online. The bowl is the same as the larger model carbs as well. Search for "Kohler 235448-S or Stens 055-533". A good clean used one is just as good as a new one. If you have trouble finding one, I should have a couple of decent used ones in my shop. Edited June 4, 2017 by rmaynard 1 Share this post Link to post Share on other sites
Mikey the Monkey 701 #7 Posted June 4, 2017 You are awesome Mr Maynard! Thanks for your help! 1 Share this post Link to post Share on other sites
rmaynard 16,840 #8 Posted June 4, 2017 Keep us updated on the 701 restoration. That's a great little tractor. Share this post Link to post Share on other sites
WHX?? 54,523 #9 Posted June 4, 2017 Yes indeed Mikey.... good tractor worthy of the effort. glad you could join us. Share this post Link to post Share on other sites
