Doug953 2 #1 Posted June 1, 2017 My 953 drains the battery while I am running it. I have to recharge after every use and carry a battery booster while I am running the little bugger. 1 Share this post Link to post Share on other sites
953 nut 63,947 #2 Posted June 1, 2017 It sounds like your starter/generator or the voltage regulator is not functioning properly. This is some information I have found helpful. Starter Generator Assembly In this article we are going to look at the starter generator assembly, how it is made, how it works, how to test it and how the voltage regulator controls it. This starter generator unit combines two items in a single unit, giving it it's unique name. There are four basic combinations, short frame [about 6 1/8" field housing] low torque and the high torque long frame [about 7 ¼" field housing]. The other option is the direction of rotation. Cub Cadets and some other applications put the drive pulley on the PTO end of the engine instead of the flywheel end. These units rotate in the opposite direction. These can be reversed by installing new field coils in the unit. The short frame units were typically installed on the 8 and 10 HP vertical shaft engines and the long frame units were usually on the cast iron block horizontal shaft engines. The longer frame allows for a longer stack of laminations on the armature and longer pole pieces and field coils, resulting in increased torque and generator output. The starter consists of an armature that is connected in series with a field coil that is wound of very heavy wire. Probably about 10 turns of 1/16 X ¼ inch copper buss. As can be seen in the following sketch the voltage applied to the A or Armature terminal goes through the field coil to the brush to the armature. A generate field coil is also connected to this brush. This coil is wound of many turns of fine wire. The other end of this coil is connected to the [F] or Field terminal. The [F] terminal is normally grounded through the voltage regulator when the unit is not generating. When a high current source such as a battery is connected to the [A] terminal the current flowing through the series [starter] field provided a very strong magnetic field on the pole piece to attract the field created in the armature. [See previous article on motor and generator principles]. Since this is a series field and it has VERY low resistance, it is capable of carrying very heavy currents and the more current that flows through it the more magnetism it creates. The more load on the armature [i.e. the harder the engine it is trying to start turns over] the more magnetism is created in the field because the motor draws more current. To illustrate how a little extra resistance, maybe just in a connection, can seriously affect the performance of a starter circuit, lets examine a hypothetical case and see what happens. Remember the power formula P = EI and 746 watts = 1 horsepower. If the engine being started turns over hard it requires more horsepower to turn it. Since the battery voltage is fixed [12V] and it goes down with load, the limiting factor is the available current and the efficiency of the starter motor. The amount of current is controlled by the TOTAL resistance in the circuit and the current available from the source. [battery]. To illustrate how critical resistance in these circuits is, lets look at an example of what happens. Remember OHMS LAW: E=IR. Lets pretend our starter motor is 100 percent efficient [not possible] and we need 1½ horsepower to crank the engine to starting speed. At 746 Watts per HP the power requirements will be 1119 watts. Lets also pretend that the battery voltage will not drop any from a constant 12 volts under the load [not possible] and we will pretend that the cables and connections have no resistance [not possible]. P = EI, I = P/E. Therefore, the current it will require will be [P] Watts 1119 divided by [E] Volts 12 = about 93.25 amps. To be able to draw this current we must have a circuit with less than __?____ Ohms. To find out, let's use the E = IR, therefore R = E/I. So, R = [E] 12 Volts / 93.25 Amps = .13 Ohms. This is assuming in our hypothetical case that the 12 volts was right at the starter. Now lets pretend that our battery cables had .13 ohms resistance also. If you add this to the resistance we calculated that the starter must have to provide 1.5HP (.13, or 13 one hundredths of an ohm) plus .13 more in the cable, then the voltage getting to the starter would be 6 volts. Half (or 50%) of the battery's voltage would be lost in the cable. Putting 12V into this circuit with .26 Ohms total resistance would result in a maximum current of: E = IR, therefore I = E/R = 12V/.26 ohms = or about 46.15 amps. Since 6 Volts would be lost in the resistance of the cable and only 6 Volts would be at the starter, if we take the P = EI and calculate the power we get 6 Volts X 46.25 Amps = 277.5 watts or about .375 horsepower. When you double the resistance in this series circuit, the power the starter would deliver was reduced to ¼ of what it would produce originally. All of this calculation is not something you would do in troubleshooting an existing system, but it illustrates in these high current circuits how a tiny little bit of extra resistance, can result in serious losses in power and excessive voltage drops. If one understands these principlesthen it is easy to take a voltmeter and identify high resistance areas and trouble shoot your starting system. It is the concept one must understand. Applying the principles of what we just discussed to Simple Troubleshooting will be addressed in one of the next articles. Now, refer back to the figure above and let's see how the generator part of the assembly functions. Now that we have our engine started, the 12 volts from the starter solenoid is removed from the A terminal and the [F] terminal is grounded by the voltage regulator. The pole pieces that concentrate the field coil magnetic field retain some residual magnetism. As the armature turns, the windings in the armature cut the magnetic field of the pole pieces and this induces voltage in the armature. This voltage is connected to the brushes from the commutator bars. These bars are nothing more than a rotary switch. As the armature turns the bars that are connected to the windings that are cutting the flux at the pole pieces rotate out of the field, the bar connected to the next winding connects to the brush and on and on it goes. As the induced voltage is connected from the commutator to the brush this voltage flows to the generate field winding. This is shunt connected [connected across the armature to the field terminal, where it gets its ground]. The resistance of this winding is normally about 8 to 12 Ohms, such that the maximum current that will flow through it is about 1 to 1½ amps. This current in this coil creates the magnetic field in the generate pole piece. As this field increases the output of the armature increases, feeding more voltage to the field coil, reinforcing the magnetic field, and resulting in more output. When the output gets above 12 volts the regulator connects the armature to the battery and the current flows to the battery charging it. When the voltage gets to about 14 volts the regulator starts to interrupt the ground on the [F] terminal. This controls the magnetic field at the pole piece which controls the amount of voltage induced in the armature. The regulator action caused by the vibrating contacts in the regulator happens at a very high rate, nearly 300 times a second. Please see the section on regulators for more details on how the regulator does this. The same thing happens when starting. When the voltage from the [A] terminal gets to the brush it connects to the bar connected to the coil that is just approaching the pole piece and the intense magnetic field there. As it approaches the center of the pole piece where it would want to stop, the brush switches to the next bar [segment] and this magnetizes the coil just approaching. So, it continues indefinitely, constantly pulling and when it just about gets there, it is disconnected and the coil preceding it is connected. The brushes don’t really run on the commutator, but the current is conducted through a microscopically thin (just a few atoms thick) cloud of gas that is created when the electrons flow to the brushes. There are several common problems associated with these units. The amount of current they can generate reliably is limited by the fact that they have only one generate field coil. Regular generators for cars and farm tractors have a fan at the front and the front and rear frames are open to allow cooling air to be pulled through. Since generating electricity creates heat due to resistive losses, the closed design also imposes limits on the amount of energy they can generate. If the commutator gets out of round, the brushes "bounce" and cause the output to be intermittent. One won’t be able to see this as the armature is typically turning about 10,000 RPM when the engine is running at governed speed. This problem gets accelerated if the rear bearing is getting worn. The rear bushing can be replaced and is available in 3 undersizes in .002 intervals. The undersize bushings are not "cut" for the oil wick and need to be before installing. Another common failure is the voltage regulator not regulating properly and the unit running "Full Fielded" and the generate field coil burning out. The field coils are available in complete sets and the generator field separately. The armatures are available remanufactured. The quality varies from manufacturer to manufacturer. We have been buying from the same company for about 18 years. When repairing one of these units the commutator on the armature should be turned in a lathe. After turning, the armature should be undercut. Undercutting takes the mica separators below the surface of the commutator bars. In generators this keeps the mica from shaving the brushes as the copper wears down. The brushes in these units have some copper added to them to reduce the resistance and handle the starting currents. Regular generator brushes out of a car or tractor generator won’t work. The starter won’t have the torque and they will be very short lived. One other thing, regulators from farm tractors or cars, even though they look EXACTLY the same, are not compatible with these units as the current sections are calibrated for 20, 25 or 30 amps of current and would burn the field coils out of these units. Check the front end [drive end] to see that the bearing has not egged the hole out where the bearing seats. Often the bearing will have up to .010 clearance around the outside race in spots usually on the side the belt pulls the armature to. The best fix is to replace the drive end frame, but sometimes they may be saved with some very high grade Loctite, not the regular stuff. Troubleshooting Charging: 1. With the engine running more than half throttle, measure the voltage at the A terminal, it should be 13 to 14.5 volts. If it is 12.5 or less, ground the F terminal, if the voltage goes up to 13 to 14.5, most likely the problem is the regulator. Other possibilities are the wire from the F terminal to the voltage regulator, and the ground on the regulator not being good. If the voltage at the A terminal is 14.5 to 17 volts when you ground the F terminal, the regulator cut-out section is probably not connecting the A terminal to the battery. If the unit is measuring 13 to 14.5 volts at the A [without an external ground applied to the F terminal] terminal, the voltage measured at the battery should be within .1 or.2 volts of the voltage measured at the A terminal, if it is the system is working correctly. 2. If the unit fails the above tests, disconnect it and remove it. Using an ohmmeter, measure the resistance between the F terminal and the A terminal. A normal reading would be 7 to 15 ohms. If it measures less than that remove the end frame and pull the armature assemble out and look at the field coil connected to the F terminal. If the insulation is scorched, or it looks as if it has been overheated it is probably shorted. 3. Inspect the brushes for wear or the leads being loose in the carbon. Look at the sides of the brushes to be sure the sides haven't worn into the indentations in the holders causing the brushes to "Hang Up". 4. With the armature out, use the ohmmeter to check from the copper commutator bars to the armature laminations or the shaft. It should show no resistance, infinity. If the reading is 0 ohms you have a shorted armature. If it is 40 or more ohms, it probably has carbon dust between the commutator bars and the frame or shaft. Blow it out all around the commutator and windings. Be warned this dust is black and messy, so do it where it won’t make a mess. Blow the field housing out at this time also. If these two tests are OK, the armature needs to be "GROWLED." This checks for shorted turns, and shorted bars in the armature. This requires a growler to do this test. Any good starter shop will have one. If the field coil needs to be replaced, one will likely need a pole shoe screw remover. This is a clamp device with a screwdriver bit on a wrench that clamps the bit in the head of the screw to remove the pole shoe that holds in the field coil. Sometimes they will come out with an impact wrench, but when the pole shoe is reinstalled one needs to be sure they it is installed perfectly straight or it will hit on the armature if the curve is not exactly parallel with the armature. At this point for most people, this would be a "take it to the shop" job. 5. Check the bushing in the end plate for looseness. If the bushing needs to be replaced one needs a blind bushing puller which costs $400.00, so this is another "shop job." Troubleshooting Starting: Check that there is 12 volts to the A terminal of the starter generator unit when starting. If not, measure step by step using the principles outlined in the FORK LIFT troubleshooting article. this will explain how to isolate the external problems. The internal problems usually are: short brushes, worn rear bushing with armature dragging on the pole shoe, shorted armature, or the start field shorted to the field housing. Low cranking torque may be caused by someone putting regular generator brushes in, because they fit. Most likely it is a high resistance problem in the power source to the unit. One little, off the subject point, about undercutting. In regular car and truck starters, you don’t normally undercut 12 volt starters, because the brushes have so much copper in them to keep the resistance down that it gets in the grooves between the bars and shorts them out, they are also hard enough that they wear off the mica. On 24 volt starters you need to undercut because they add some carbon to the copper in the brushes to keep the brushes from tearing up the commutators. They are softer and the mica gets them, also with the extra carbon the shorting problem is lessened. In many big truck and heavy equipment starters, the only difference between the 12 volt and 24 volt versions is the undercut armature, the material the brushes are made of and using the correct [12 or 24 volt] solenoid. The windings are different in the 12 and 24 volt solenoids, plus the contacts in the 24 volt ones are usually silver, or silver brazed on the copper faces. Neat Huh! Dealing with the problems of resistance that go with low voltage, high current systems is why the automobile companies are going to 42 volt systems. The automotive industry has recently settled on 42 Volts as the best option to deal with the increased demands for power in the automobile. In our starter trade publications they are saying that in 3 years some of the car companies will have 42 volt systems in the showrooms and in 5 years all will be there. This means they will be able to use significantly smaller wire and cables and to power many more electrical accessories. 12 Volts will soon be as obsolete as 6 Volts is now. 2 Share this post Link to post Share on other sites
pfrederi 19,790 #3 Posted June 1, 2017 For the more simple minded of us, like me, ground the F terminal on the generator with a wire while it is running. You should hear the engine slow a bit (or if you have a multimeter the voltage measured at the battery should go up to 14 or better)...If it does the generator is OK and most likely problem is the regulator (or bad connections somewhere). Share this post Link to post Share on other sites
953 nut 63,947 #4 Posted June 1, 2017 One other thought just came to mind. Presuming you are using the large starter switch on the dash, it could be sticking and drawing currant while the engine is running. Not likely, but worth checking. Share this post Link to post Share on other sites
squonk 45,371 #5 Posted June 1, 2017 (edited) Another possibility is a winding bad in the Genny. I have seen this happen and the unit still function normally. It only takes one bad strand to draw current. Edited June 1, 2017 by squonk Share this post Link to post Share on other sites
Doug953 2 #6 Posted June 2, 2017 13 hours ago, Doug953 said: My 953 drains the battery while I am running it. I have to recharge after every use and carry a battery booster while I am running the little bugger. As you can tell I am really new at this -- thank you all for the info. I will try and figure out the problem with the things you suggested. I will get back to you in a few days. Thanks again - 1 Share this post Link to post Share on other sites
Racinbob 12,663 #7 Posted September 6, 2017 I found this somewhat older thread and found it interesting. I typically don't have a problem with electrical issues but I was a bit befuzzled on this one and had to do some research on a.....a......a......Cub Cadet. It belongs to my nieces husband and he asked me to help out. Almost immediately I discovered the VR was fried. OK, get a new one and we'll go from there. He took it back home and got a new VR and installed it. He asked me to come over to check out his work. Still no charge. The wiring harness was a mess so I told him to get several colors of wire and bring it back to my place and I'll make a new harness before I do any more troubleshooting. I noticed that he installed a 4 wire VR and every diagram for a 1967 Cub 123 showed a 3 wire. He grabbed the old one and just matched it up. Enter the research. I discovered that the Cub 70 and 100 used a 4 wire and probably others but I didn't need to go further with the models. The 123 only used 3 wire. I've been told a 4 wire can be used and just to ignore the 'L' terminal. I'm not sure but that seems to make sense. As I removed the old harness I saw that someone had tried to wire it according to the 70/100 diagram but missed the target big time. I knew it wasn't my nieces husband. So I asked him how long he's had the tractor. "About 10 years". Has it ever charged since you've had it? "I'd have to say no to that" . Apparently some PO tried to wire in the 4 wire VR and utilize the 'L' terminal. I made the new harness and just used the 3 terminals. Fired it up with my fingers crossed but nope, no charge. He had a Labor Day parade to go to that his daughter was in so he left the tractor here. Knowing some of the dumb things I can manage I tripled checked my wiring. Correct. I polarized the SG. Still nothing. He told me he had taken the SG in to get it bench tested and it was good. I'm thinking it's not so I decided to go that direction. Voltage at the 'A' terminal = 0. Ground the 'F' terminal and it's still 0. The resistance between the 'A' and 'F' terminals is 5.8 ohms. A bit low. I'm thinking with the resistance just being a little low it could be an easy fix inside the unit but I really don't want to open it up. These little favors seem to always snowball. He just wanted to get it working because a friend of his wants to buy it. It's time to let somebody else have the problem. I think I've covered all the bases on determining it's the SG but I have one uncertainty. Will a 4 wire regulator work in place of a 3 wire by just using the 'B' 'G' and 'F' terminals? No offense to the guys on the other forum but my confidence level would be with the guys here. One more thing. I hope this isn't considered hijacking this thread. I figured my issues could help @Doug953 with his. Share this post Link to post Share on other sites
953 nut 63,947 #8 Posted September 6, 2017 Bob, just for grins take a look at the data plate on the S/G and make sure it is for a Cub; they rotate backward from ours. 3 Share this post Link to post Share on other sites
pfrederi 19,790 #9 Posted September 6, 2017 (edited) Just got a S/G back from my local Genny guy. He replaced the original (bad) VR 4 terminal with a 3 terminal absolutely no problem he said and it works. Gen terminal goes go the A Armature post (which also has the starter cable. Batt terminal goes to + on battery. Good point on direction of rotation!!! Edited September 6, 2017 by pfrederi 3 Share this post Link to post Share on other sites
Racinbob 12,663 #10 Posted September 6, 2017 Never thought about that Richard. There's no tag on it but the tractor starts fine until the battery dies. Excellent Paul. I wanted to verify that. I've got it wired that way and according to the 123 diagram. Share this post Link to post Share on other sites
Racinbob 12,663 #11 Posted September 6, 2017 1 hour ago, pfrederi said: Just got a S/G back from my local Genny guy. He replaced the original (bad) VR 4 terminal with a 3 terminal absolutely no problem he said and it works. Gen terminal goes go the A Armature post (which also has the starter cable. Batt terminal goes to + on battery. Good point on direction of rotation!!! It just hit me Paul. I'm trying to use a 4 terminal wired as a 3 terminal. I should have been more clear. That's sorta, kinda like replacing a 4 with a 3 but not exactly. Do you see any reason I couldn't just ignore the 'L' terminal as long as it's wired correctly on the 3 terminals? Richard, I didn't really make it clear that the tractor was starting fine in my original post. I also didn't realize Cubs spin backwards. Since it spins the Cub backwards rotation I'd think it's will charge that way as long as it's good. Share this post Link to post Share on other sites
953 nut 63,947 #12 Posted September 6, 2017 1 hour ago, Racinbob said: starts fine OK, it has the proper rotation but didn't pass the tests I had posted in the earlier post #2. Time to ask the owner if he wants to pay to have it repaired or sell as-is. The start wingdings are separate from the charging wingdings. 1 Share this post Link to post Share on other sites
Racinbob 12,663 #13 Posted September 6, 2017 I agree Richard. The field windings seem good. I removed the belt and spun it up and then removed the power. As it coasted down I grounded the 'F' terminal and it made a rapid stop. What do you think about wiring a 4 terminal VR as a 3 terminal? I'm thinking it would be fine but I'm not certain. At this point I'm confident it's the SG but I'm curious about that for my own knowledge. Share this post Link to post Share on other sites
953 nut 63,947 #14 Posted September 6, 2017 8 minutes ago, Racinbob said: What do you think about wiring a 4 terminal VR as a 3 terminal? This is new to me, I would like to hear more about it from @Save Old Iron or another member who has knowledge of them. Share this post Link to post Share on other sites
Racinbob 12,663 #15 Posted September 7, 2017 I would like to hear what SOI has to say about it too but he hasn't been here for quite a spell. From what I've researched the 'L' terminal permits current from the generator to be diverted to the load without it passing through the VR. This allows the generator output to increase to a value sufficient to handle the load and still charge the battery. Further research this morning brought me to another forum where several posts were made that stated a 4 terminal VR can be used as a 3 terminal by just ignoring the 'L' terminal. 1 Share this post Link to post Share on other sites
Lindroth 0 #16 Posted May 9, 2018 Hi all. I have the same problem that i have to use a batterycharger after a couple of hours or the engine will stop. Can someone help me where the generator is located. It´s a C-160 i have. Thank´s in advance! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #17 Posted May 9, 2018 This thread has been about a combination starter/generator that is belt driven off a pulley mounted on the engine flywheel. Later they went to a starter with a Bendix gear that engages a gear around the outside of the flywheel. This system has a stator behind the flywheel that produces AC current that is rectified and controlled by a solid state rectifier/regulator to charge the battery. Two totally different systems. Suspect you have a 1975 model C-160 which uses the alternator stator. The body of the finned aluminum regulator must have a good ground to the battery negative (-). Many add a ground wire from one of the regulator mounting screws to a known good ground. There are two AC terminals on the regulator that connect to the two stator wires coming from the stator behind the flywheel. There is a third terminal marked DC+ and that is the output that charges the battery. With the key ON but the engine NOT running check the voltage across the battery terminals. Now move the red test lead to the DC+ terminal on the regulator. You should have the same voltage reading. If not the wiring is a problem and the charge currant has no way of getting to the battery. Don't forget to turn the key OFF after testing. Make sure all the wire connections are clean and tight. Often the connections at the regulator have been poor and the resistance has created heat that has melted the plastic terminal cover. To test further follow the instructions in the service manual Section 7.7 Let us know what you find. Garry 1 1 Share this post Link to post Share on other sites
953 nut 63,947 #18 Posted May 9, 2018 3 hours ago, Lindroth said: Hi all. I have the same problem that i have to use a batterycharger after a couple of hours or the engine will stop. Can someone help me where the generator is located. It´s a C-160 i have. Thank´s in advance! I would suggest you start a new post for each specific unrelated question you have, that way a new set of eyes will see the question and be able to offer help. At the top of the home page you will see "Create", that will bring you to a subject drop down box and you can take it from there. Lots of good info. here. http://www.wheelhorseforum.com/forum/56-finding-your-way-around-in-redsquare/ Garry did a good job answering your question on the charging system. You may want to take your battery to an auto parts store to have it load tested too. 1 Share this post Link to post Share on other sites
