tbear0714 0 #1 Posted May 29, 2017 I have a 95 314. The shock on the clutch went out and was wondering if anyone has any ideas or has tried just installing a return spring just as a temp fix. Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted May 29, 2017 It should work with spring that's how they were setup before they went to the shock 3 Share this post Link to post Share on other sites
pfrederi 19,930 #3 Posted May 29, 2017 Look for many many years WH manual trannies worked with out shocks. I think WH found people did n't know how to use a clutch and put in the unnecessary modification. Get a OEM belt a spring and she will be fine. 2 Share this post Link to post Share on other sites
cschannuth 3,819 #4 Posted May 30, 2017 2 hours ago, pfrederi said: Look for many many years WH manual trannies worked with out shocks. I think WH found people did n't know how to use a clutch and put in the unnecessary modification. Get a OEM belt a spring and she will be fine. Where can a new clutch spring be found? Thanks. Share this post Link to post Share on other sites
Achto 31,034 #5 Posted May 30, 2017 3 minutes ago, cschannuth said: Where can a new clutch spring be found? Thanks. I usually measure the distance between the mounting point, subtract an inch or so. Then go to my local hardware store to get a spring that is close the size that I need. 1 Share this post Link to post Share on other sites
Marv 994 #6 Posted May 30, 2017 Clutch spring is available from Toro. 108035 Marvin 1 Share this post Link to post Share on other sites
tunahead72 2,621 #7 Posted May 30, 2017 7 minutes ago, Achto said: I usually measure the distance between the mounting point, subtract an inch or so. Then go to my local hardware store to get a spring that is close the size that I need. I tried that once, and it worked just okay. I eventually replaced it with the genuine Toro / Wheel Horse spring, which worked (and continues to work) much better. 1 Share this post Link to post Share on other sites
chip61 666 #8 Posted May 30, 2017 You can order the spring from Amazon also. Share this post Link to post Share on other sites
