TIGman 2,006 #1 Posted May 20, 2017 (edited) Finally had a little bit of a break at work so I had time to weld together the "faux" grader blade for my Simplicity/ Allis Chalmers tractors that I started last fall. Guess you could say I did some "Reverse Engineering" using some line drawings and photos of a blade and calculation of dimensions. Edited May 20, 2017 by TIGman 8 Share this post Link to post Share on other sites
squonk 43,809 #3 Posted May 21, 2017 I did almost the same thing a few years back. Only I made it for both the rear and mid point. Those heavy AC blades work awesome! 2 Share this post Link to post Share on other sites
TIGman 2,006 #4 Posted May 21, 2017 I was thinking about making up an adapter for it so I can also use it as a back blade on the slot hitch. Share this post Link to post Share on other sites
