here 4 the horses 1 #1 Posted January 29, 2009 this is my very first wheel horse 607! with aa 6hp techumse! very proud of this machine, this is the one i turned into a puller...but its all stock but i do have a few motor mods done!..bored over, bigger vavles, bigger cam,pushing 15 horse and a chrome stack, and ag tires for pulling......AND THERE HASNT BEEN ANY CUBS OUT PULLIN IT! Share this post Link to post Share on other sites
Teddy da Bear 11 #2 Posted January 29, 2009 Very sweet Jeff! :thumbs: Share this post Link to post Share on other sites
Coadster32 793 #3 Posted January 29, 2009 Nice job. Go horses!! :horseplay: Share this post Link to post Share on other sites
WHC-125 4 #4 Posted January 29, 2009 Very nice horse My first Wheel horse was 63 633 that I partially restored Share this post Link to post Share on other sites
pond195520032003 27 #5 Posted January 29, 2009 nice one Jeff :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted January 29, 2009 this is the one i turned into a puller...but its all stock but i do have a few motor mods done!..bored over, bigger vavles, bigger cam,pushing 15 horse 15hp..... Really????? 15hp!?....... Seriously????? How big did you bore it? Where did you get the valves? Who did the cam work? How many rpm does it turn? Did you remove the governor? What fuel are you running in it? What carburetor are you using? Are you using the stock ignition? Are you guessing at the hp or did you actually have it on a dynomometer? It does look like a clean little tractor. :whistle: Share this post Link to post Share on other sites
here 4 the horses 1 #7 Posted January 29, 2009 15hp..... Really????? 15hp!?....... Seriously????? How big did you bore it? Where did you get the valves? Who did the cam work? How many rpm does it turn? Did you remove the governor? What fuel are you running in it? What carburetor are you using? Are you using the stock ignition? Are you guessing at the hp or did you actually have it on a dynomometer? It does look like a clean little tractor. yes TT it has chevy 350 valves a bigger cam i order from westcoast pulling co. and when i use it to pull i run high octane gas and when im just using it to plow snow i run 87 octane. i use the original ignition with bigger spark plug, and i still have the governer in it u just have the screw wayyyy out..lol...and when i plow snow or somehting small i screw it in!.and the CARB...its off of a bigger techumse not sure which model all i kno is the west coast pulling co. hooked me up with it and it works great bolts right up to it!....and its bore is .30 over. and yes i had it put on a machine and it pushing like 14 and 3/4 so i just say 15 horse!...and thanks to everyone that has commented on this machine its my pride and joy!..thanks jeff Share this post Link to post Share on other sites
here 4 the horses 1 #8 Posted January 29, 2009 and also tt the seriel number is 296203....what year would that be?? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #9 Posted January 29, 2009 The 607 is a 1967, no matter what the serial number is. Share this post Link to post Share on other sites
here 4 the horses 1 #10 Posted January 30, 2009 thank you!.....i always wonderd what the year was!....i have a question i have a old 2 blade deck for this tractor that i use every now and then. where is the ID plate at on this thing iv looked everywhere and i cant find it!....i also have some number for someone to help me get what years they are!: c121: 91-12k802-12558 and under that 0047 mower deck to c121: 95-42MRO-31221 and under that 9097 snow blade to c121: 96-42BC01-14614 WHAT YEARS ARE THESE THANK YOU A MILLION! Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #11 Posted January 30, 2009 If you go here: https://lookup3.toro.com/partdex/index.cfm?...es&xCaller=Toro click on the "model search" text in the green header bar and enter the model number in the box on the next page that opens. Try it with your own numbers, but remember - you have to enter them exactly as they are on the tags, including the hyphen. (the exception is the tractors with a T- prefix. You only need to type in the number, like "607") By the way, your mower deck model number is missing the last digit, and the "O" should actually be a 0 (zero). Share this post Link to post Share on other sites
here 4 the horses 1 #12 Posted January 30, 2009 ok i swore that was the last number but ill check tomarrow..and ok ill check that out..........where are the ID tags on the old 2 blade mowers i have one and cant find it nywhere? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #13 Posted January 30, 2009 It probably fell off long ago. Do you know if it's 32 or 36 inch cut? Is it a stamped shell with rounded corners, or is it a sharp cornered bent/welded rectangular shell? Share this post Link to post Share on other sites
here 4 the horses 1 #14 Posted January 30, 2009 im pretty sure its 32 and its rounded corners! for sure!? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #15 Posted January 30, 2009 Try "RM-327" as a model number then. Share this post Link to post Share on other sites
