1046 1 #1 Posted May 19, 2017 I'm trying to find out if any other rear wheels fit other than wheel horse. Share this post Link to post Share on other sites
Tankman 3,528 #2 Posted May 19, 2017 I have my doubts. Purchased a pair of nice turfs some time ago, were from a Simplicity. The rim offset didn't work for my intended Horse. Nice post, I've often thought about the subject. Check back, Horse cowboys know!. Share this post Link to post Share on other sites
pfrederi 19,931 #3 Posted May 19, 2017 I suppose it depends. What you need to do is measure the backset on your current wheels and use that as a guide. Also you need to make sure the bolt pattern matches and that the center hole is the same size. Share this post Link to post Share on other sites
Chris G 3,369 #4 Posted May 19, 2017 (edited) I'm pretty sure most of the old 6-12 rims match up. If I remember correctly its when you get to the 8.5 rims is were you have to be careful. Cause the offsets differ and the valve stem is on different sides for some. And I only say valve stem location, because example I had a set of 8.5 on a horse that we're really rough so I picked up a pair off a Ford LGT 145. The off sets we're the same but once I got them mounted and went to install the weights it was a no go cause of the valve stem. Edited May 19, 2017 by Chris G 1 Share this post Link to post Share on other sites
SPINJIM 1,996 #5 Posted May 19, 2017 Depends on the model of WH, and the rear offset on the wheel rim. I have a set of Cub Cadet rims on on my C-120 with Ag tires, but they wouldn't fit on a WH with Auto trans because the hydro pump sticks out farther than the 8 speed trans. Also, might not fit on a C-121 or a 312 because the fuel tank under the seat is wider than the older models with just a tool box under the seat. If the wheel rim rear offset is 1 1/2 to 2 inches, good chance it will fit using a 8.50 or 9.50 wide tire, assuming the 5-hole bolt pattern of correct. Early Sears wheels and some other older brands also seemed to use the same rims. Measure twice, and buy once. Jim 5 Share this post Link to post Share on other sites
1046 1 #6 Posted May 20, 2017 Thanks Guys. Just hoping to get tires a little cheaper. 1 Share this post Link to post Share on other sites
Tankman 3,528 #7 Posted May 20, 2017 9 hours ago, 1046 said: Thanks Guys. Just hoping to get tires a little cheaper. If you're looking at a pair, good $$$ deal, get 'em. Try them and if the rim offset isn't a go you need spacers. http://xtrememotorworks.com/Parts Catalog/Dual-Wheel-Spacers-Cub-Cadet.html Share this post Link to post Share on other sites
ebinmaine 77,397 #9 Posted June 13, 2017 On 5/20/2017 at 6:52 AM, Tankman said: If you're looking at a pair, good $$$ deal, get 'em. Try them and if the rim offset isn't a go you need spacers. http://xtrememotorworks.com/Parts Catalog/Dual-Wheel-Spacers-Cub-Cadet.html Pretty awesome lookin stuff there... Saved that to the favorites bar. Thanks ! Share this post Link to post Share on other sites
AMC RULES 37,254 #10 Posted June 13, 2017 An angle grinder & cut off wheel is all you need to reset the depth of any rim center. Then simply, weld into place. 2 Share this post Link to post Share on other sites
JAinVA 4,638 #11 Posted June 13, 2017 (edited) I only have a couple WH rims welded with a bead like shown.The angle grinder trick is the deal if your wheels are built that way.Most of my rims are spot welded at the rim/center junction. Miller tire has rim blanks and center sections.You can weld up new wheel sets using what they have. Edited June 13, 2017 by JAinVA Share this post Link to post Share on other sites
AMC RULES 37,254 #12 Posted June 13, 2017 Those were MTD/Crapsman rims I pictured above. Share this post Link to post Share on other sites
ebinmaine 77,397 #13 Posted June 13, 2017 2 hours ago, AMC RULES said: An angle grinder & cut off wheel is all you need to reset the depth of any rim center...... Thanks for putting the face shield in the first photo... good safety reminder. I appreciate the demo photos 'cause I'm thinking of doing the same thing and wondered if its possible. Now I know. I have 2 inch wider-than-stock rear wheels on my B80 and all of the extra 2 is on the Inside and now I can't mount an auxiliary hitch I bought..... Yet. 1 Share this post Link to post Share on other sites
