cafoose 3,572 #1 Posted May 16, 2017 Is there an easy way to remove the flywheel shroud on my 520-HC? I removed all the bolts I could find, the coil, and some linkages and I still had to twist and wrestle with it to get it off. I'm going to replace the module under the flywheel because it won't start when hot. The coil is new and it runs better but the problem is still there. I got the shroud off but not the flywheel yet. I had to stop because I had to go to work. I plan on finishing it tomorrow. Share this post Link to post Share on other sites
cleat 8,715 #2 Posted May 16, 2017 That is just one of those things that come off if you hold your mouth just right. Going back on is the same way. 1 Share this post Link to post Share on other sites
6bg6ga 272 #3 Posted May 16, 2017 A impact wrench would be nice to remove the center bolt but not necessary. Having gotten rid of my impact a long time ago I wrenched mine by hand but not without a few choice words. I ended up using a piece of apple wood to keep the flywheel from turning. Before others chime in here yes I know your not supposed to do it because you could break a cooling fin. 1 Share this post Link to post Share on other sites
GMan 82 #4 Posted May 16, 2017 Guys, Best way to hold the flywheel during removal is the use a pair of vicegrips on the ring gear up next to the governor arm support casting............Works every time! ........Gary 1 Share this post Link to post Share on other sites
cafoose 3,572 #5 Posted May 16, 2017 3 hours ago, 6bg6ga said: A impact wrench would be nice to remove the center bolt but not necessary. Having gotten rid of my impact a long time ago I wrenched mine by hand but not without a few choice words. I ended up using a piece of apple wood to keep the flywheel from turning. Before others chime in here yes I know your not supposed to do it because you could break a cooling fin. I have an impact wrench both air and electric. 18 minutes ago, GMan said: Guys, Best way to hold the flywheel during removal is the use a pair of vicegrips on the ring gear up next to the governor arm support casting............Works every time! ........Gary I'm planning on using the impact wrench to remove the flywheel. I was asking for tips on removing the shroud around it without bending and twisting things. Share this post Link to post Share on other sites
