bork
ID tag location
bork
I'm new. I see 1057 on hood decal, but where is this ID tag normally located?
CasualObserver
:thumbs: bork. I moved your post into it's own topic here. The ID tag on older tractors is usually found either directly under the dash, or on the left side of the dash tower. Later on they moved under the seat. Yours should be directly underneath the dash on the dash tower. You may have to lean over very far to see it, they liked to tuck them right up at the top. If you don't see it at first, look carefully, it may have been painted over.
pond195520032003
:whistle: Bork, like Jason stated its under the dash :thumbs:
bork
Aha! found it! Right where you guys said. Just had to stand on my head, a little more. Thanks !!!
