gwest_ca-(File Mod) 12,007 #1 Posted May 13, 2017 Starting in 1971 the model numbers got a 6th digit following the 5-digit model number. After seeing these in lists realized the significance of the 6th digit. x-xxxx-6 minus 5 = 1 = 1971 x-xxxx-7 minus 5 = 2 = 1972 x-xxxx-8 minus 5 = 3 = 1973 x-xxxx-9 minus 5 = 4 = 1974 The attachment model numbers were the same. Recently the model 1-6041 came up and Toro has this listed as a 1970 model. Believe it should be 1969 as 19 1969 tractor model numbers use 4 for the 4th digit and 1 model made in Belgium dosen't. Another observation is no other model number for the 1969 Raider 10 has shown up. In 1970 all 23 models use a 5 for the 4th digit. Back to the significance of the 5. In 1969 the 4th digit 4 minus 5 could be 9 = 1969 In 1970 the 4th digit 5 minus 5 could be 0 = 1970 Interesting. 3 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted May 13, 2017 You have put a lot of thought into this! Thanks for all your help with Wheel Horse information. 2 Share this post Link to post Share on other sites
953 nut 64,169 #3 Posted May 13, 2017 Garry, you amaze me with the amount of helpful information you share with us. 1 Share this post Link to post Share on other sites
rmaynard 16,877 #4 Posted May 13, 2017 You have too much time on your hands. You need a hobby. for that info and all the time you spend documenting this stuff. 1 Share this post Link to post Share on other sites
