Calling All Hydraulic Gurus: 6621 & 8363 Lift Control Valves
By
ztnoo, in Transmissions and transaxles
Similar Content
By ztnoo
Would anyone happen to have the 8363 hydraulic control valve with operates the cylinder which lifts the mower deck off your tractor???
I need a pic of the bottom side of that valve. The valve part number is 8363.
I need to replace the spool valve seals inside the valve body on my tractor (they are leaking profusely) and I'm trying to figure out a way to do that without tearing the tractor half way apart.
The seal kit instructions from Lowell (wheelhorseman1000 at Red Square) says the spool valve is secured with a snap ring on the bottom of the valve body.
I need to understand what the bottom of the valve looks like and then find a way to get the valve body out, get the new seals installed on the spool valve, and get it reinstalled as easily as possible with a minimum amount of wrenching.
If you don't have a pic of that, could you snap and post or send me a few views of it???
A pic of the bottom of that valve might help steer me in what I may try or not try do.
Any help would be much appreciated.
Here's my post on this at RS:
Thanks,
Steve
