Michael Bullington 5 #1 Posted January 27, 2009 Quick Question okay will the old style with generator engines produce a spark with a battery? I was checking one of my engines just by turning the flywheel and no spark, someone told me i needed a battery for fire..Is this correct? My tecumsehs fire without batteries please explain if different Second question, Can you buy a new carb that is original for the 8, 10 and 12 hp kohlers..(pre 70) Thanks fellow wheel horse members!! :horseplay: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted January 27, 2009 If the Kohler has an externally-mounted automotive-style 12 volt ignition coil, then it must have a battery. Most Tecumseh engines (some Kohlers too) have a magneto to produce spark - which do not require a battery. Replacement carburetors are available new, but can sometimes be rather expensive depending on the model & size. Share this post Link to post Share on other sites
