erickson13455 1 #1 Posted May 7, 2017 I am looking for some help. I have a cub cadet 3225 with the kohler command 22, that I just purchased. I took it a part to clean all the fins and all the build up off. OK, so there is a wire that is next to the voltage regulator. I can't remember where it goes. I believe one end of the wire was actually connected to the screw that holds the regulator in place because it had that screw in the lug yet. I can't remember if it was the top or bottom location and where the other end goes. Is anyone familiar with these engines. Thanks! Share this post Link to post Share on other sites
erickson13455 1 #2 Posted May 7, 2017 Any ideas ,for this kohler CH22 wiring Share this post Link to post Share on other sites
pfrederi 19,791 #3 Posted May 7, 2017 Most of us here are familiar with Wheel Horses...not so many knowledgeable about cub cadets. I am not aware of any WHs that used a Kohler Command 22 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,980 #4 Posted May 7, 2017 The CH20 was used in the 5xi models. You may find something in the tractor service manual Or the engine service manual Garry Share this post Link to post Share on other sites
pappaginp 0 #5 Posted May 7, 2017 (edited) i have a kohler command 22 one end goes to the screw that holds the regulater the other end goes to a good ground pappaginp Edited May 7, 2017 by pappaginp Share this post Link to post Share on other sites
mikeeyre74 290 #6 Posted September 15, 2017 I just pulled my shroud off yesterday to access the coils. That's just a ground strap, and it goes into any screw that threads into somethign metal in the engine. In my case, on my CH22 in a %22xi, it went into the next engine shroud bolt UP from the regulator itself, which was just about 4" or so above the regulator. Share this post Link to post Share on other sites
