lercher 1 #1 Posted May 5, 2017 Hello . new to this but bare with me . we got a radier 10 6speed believe it's a 10hp. It ran great when we picked it up but the ignition switch was going . we put two tsc ones on n the both burnd out . so I got the right switch and it cranks just fine but now no spark could I have messed something up with the other two switches .got juice to the voltage regulator . but when it cranks it goes out . could the regulator be bad . thanks Share this post Link to post Share on other sites
Ed Kennell 44,635 #2 Posted May 5, 2017 This may help. 1 Share this post Link to post Share on other sites
pfrederi 19,784 #3 Posted May 5, 2017 (edited) It is possible your switch fried the magneto or if you have a breakerless system fried it. What is teh spec number for your engine? Edit; Depending on the year you may have a Kohler or a Techumseh Need more info. Model # of tractor ans Spec Number of engine if Kohler. if it was a Techumseh and you used a battery ignition switch there is a good chance it killed it. sorry Edited May 5, 2017 by pfrederi 1 Share this post Link to post Share on other sites
lercher 1 #4 Posted May 5, 2017 Okay I'll find out tonight when I'm home Share this post Link to post Share on other sites
pfrederi 19,784 #5 Posted May 5, 2017 Good news if it is an original Kohler it should be a battery ignition system. That would not be harmed by the wrong switch. Share this post Link to post Share on other sites
lercher 1 #6 Posted May 5, 2017 I'm like 95 % sure it is but I'll find out for sure Share this post Link to post Share on other sites
953 nut 63,918 #7 Posted May 5, 2017 We will get it up and running, just need a bit more info. Share this post Link to post Share on other sites
lercher 1 #8 Posted May 5, 2017 Model # mm100-115145b Serial 9162. 08048 Can't tell if it's mm or nn but that's what I got off engine cover . fly wheel side Share this post Link to post Share on other sites
oldredrider 2,553 #9 Posted May 5, 2017 Probably "HH". Techumseh 10hp. Share this post Link to post Share on other sites
lercher 1 #10 Posted May 5, 2017 So good chance the i messed the magneto up and that's not fixable ? Share this post Link to post Share on other sites
oldredrider 2,553 #11 Posted May 5, 2017 If the mag is fried, it's expensive to replace... $200. Share this post Link to post Share on other sites
lercher 1 #12 Posted May 5, 2017 Okay want else could be the problem I got one wire that goes to the regulator n two that come out to the engine . I'm not getting juice from that when cranking Share this post Link to post Share on other sites
953 nut 63,918 #13 Posted May 5, 2017 Take a look at this manual. I don't own any Tecumseh engines, but know that some had points and condenser under the flywheel. If you have points it can be converted to a "Battery Ignition" system using a coil with an internal ballast resistor. Take a look at the manual and compare it to your engine so we can narrow down the possibilities. Share this post Link to post Share on other sites
lercher 1 #14 Posted May 5, 2017 Okay I will when I get a chance . it has a spark plug wire and ignition control all in one piece. The ignition mounts right above the fly wheel. On the cover it says soild state ignition system if that helps Share this post Link to post Share on other sites
pfrederi 19,784 #15 Posted May 5, 2017 The wires from the engine to the regulator are not involved in the ignition system. They are for charging the battery. The regulator itself has nothing to do with spark. Do you have a $4 spark plug tester as from harbor freight?? if not pull the plug lay it on the block and crank the engine...any sign of spark?? If not i am afraid you used a battery ignition switch (did it have an "I" terminal on it?? or an "M" terminal) if you did the Solid State ignition is most likely toasted. Searching on line there are some ways to replace the ignition system...for a price. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,976 #16 Posted May 5, 2017 Should be an early 1970 tractor model 1-6051. Garry Share this post Link to post Share on other sites
wildman 205 #17 Posted May 5, 2017 TSC switch won't work in your horse Share this post Link to post Share on other sites
lercher 1 #18 Posted May 7, 2017 Okay guys so the problem is the magneto thing behind the fly wheel . So my question now is . Is there any Kohler I can easily replace with Share this post Link to post Share on other sites
pfrederi 19,784 #19 Posted May 7, 2017 Just about any K series 8-16HP. But make sure it is a Spec number used for Wheel Horses as You need a fairly long Crankshaft on the PTO side of the motor. If not a WH spec measure your current crankshaft and make sure the replacement engine crank is at least as long. Used replacements for your SS Mag are available, also if you search there are plans for replacing it with a battery coil system. Where in PA are you? If you decide to replace it I might be interested in buying it. 1 Share this post Link to post Share on other sites
lercher 1 #20 Posted May 7, 2017 Okay I would like to fix what's there but I'm not have much luck finding parts . And I'm still kicking the idea around in my head about going battery coil system . But around Lebanon county Share this post Link to post Share on other sites
pfrederi 19,784 #21 Posted May 7, 2017 2 hours ago, lercher said: Okay I would like to fix what's there but I'm not have much luck finding parts . And I'm still kicking the idea around in my head about going battery coil system . But around Lebanon county Here is an alternative http://overnight-solutions.com/index_files/Page682.htm Share this post Link to post Share on other sites
6bg6ga 272 #22 Posted May 7, 2017 There is another way to skin a cat if your game. You can easily use a trigger (Hall Effect Switch) to run your ignition. There are even inexpensive kits out there or one can make up something to work. Ignition on any of these tiny engines is very primitive. I put together a rough idea on how one can make their own electronic ignition in my B43E engine post. If you want help or would like to develop a DIY ignition system why not start another thread and maybe we can have some kind of sticky if you guys have that sort of thing on this forum. 1 Share this post Link to post Share on other sites
lercher 1 #23 Posted May 7, 2017 If i.knew where to start I would be game. But I think I'm gonna look into that over night solution Share this post Link to post Share on other sites
953 nut 63,918 #24 Posted May 8, 2017 10 hours ago, pfrederi said: Here is an alternative http://overnight-solutions.com/index_files/Page682.htm That is a great product, and it will probably work with the TS switch that he already bought. Share this post Link to post Share on other sites
6bg6ga 272 #25 Posted May 8, 2017 37 minutes ago, 953 nut said: That is a great product, and it will probably work with the TS switch that he already bought. I'm sure its a great product. I would have thought some of the brains on this forum would have come up with something as good for a fraction of the price. Share this post Link to post Share on other sites
