jjs 0 #1 Posted May 4, 2017 Dear team, i have a C161 wheelhorse and looking for a tiler. I found a 12519 tiler but don't know if it is compatible, how do I determine if it is or nor? Thank you, joe Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,764 #2 Posted May 5, 2017 It will likely fit but the lift hardware is different. The C-161 has the fuel tank under the seat which was not there on the 1973-74 models. 1973-74 This is what you need to end up with This operator manual should help The 7-1251-9 you found is for a model 7-1251. The 9 on the end is not used but tells us it is a 1974 model. Subtract 5 from that 6th digit and you get the model year. 9-5=4=1974 Garry Share this post Link to post Share on other sites
