hcminis 1,796 #1 Posted May 2, 2017 Picked up this little gem yesterday. Not sure what model the tractor is yet. Sickle measures 44"..... I'll look for maual today. So far it runs good and sickle is very nice. The drive belt on sickle keeps slipping off. Never been around one of these so not sure what the problem is yet 13 Share this post Link to post Share on other sites
Tankman 3,528 #2 Posted May 2, 2017 Wow! Good looking Horse. Jealous. 1 Share this post Link to post Share on other sites
953 nut 69,095 #3 Posted May 2, 2017 That is a sweet looking survivor! 2 Share this post Link to post Share on other sites
new2horses 288 #4 Posted May 2, 2017 DJ, You don't want that thing, it just doesn't fit with your nice herd. Just bring it to me in June and I'll take it off your hands. 3 Share this post Link to post Share on other sites
Achto 32,619 #5 Posted May 2, 2017 (edited) 1 hour ago, hcminis said: Not sure what model the tractor is yet Nice find!! Tractor looks like an early Raider. Does it have an 8 speed transmission? Edited May 2, 2017 by Achto 1 Share this post Link to post Share on other sites
hcminis 1,796 #6 Posted May 2, 2017 Determined it is a Raider 9. Model number 6931 3 Share this post Link to post Share on other sites
elliot ness 1,916 #7 Posted May 2, 2017 Nice score. Share this post Link to post Share on other sites
hcminis 1,796 #8 Posted May 2, 2017 2 hours ago, new2horses said: DJ, You don't want that thing, it just doesn't fit with your nice herd. Just bring it to me in June and I'll take it off your hands. I'd be happy to bring it to you for a very nice price.....lol NOT. Gonna keep this in hopes I will be able to mow my creek banks easier 2 Share this post Link to post Share on other sites
hcminis 1,796 #10 Posted May 3, 2017 Worked on the sickle for a while last night. The adjustment bolt is bent so will need to replace it. Did a search on the John Deere belt and it is a 60". Plus, not sure the bar is moving to allow belt to be tightened. So gonna take the sickle bar off and change belt and make sure everything is free and not seized up. Plus, motor started acting up like carburetor needed cleaned. Would run fine and then start to die....then would only run on full choke....then would only start for a few seconds then die. Share this post Link to post Share on other sites
Thegearhead0324 1,824 #12 Posted May 7, 2017 Very nice, a horse with the sickle attachment a definate plus! Share this post Link to post Share on other sites
hcminis 1,796 #13 Posted May 10, 2017 Well, after working on it a little more, found out it is the early SMS-425. This was for the Round Hoods....so....may be trying to mount it on the 701. OH..... additionally, if anyone has pics of yhe engagement pedal setup I wpuld greatly appreciate it 4 Share this post Link to post Share on other sites
Thegearhead0324 1,824 #14 Posted May 10, 2017 Here's a pic of mine... not sure if it's the same set up.. 1 Share this post Link to post Share on other sites
hcminis 1,796 #15 Posted May 11, 2017 14 hours ago, Thegearhead0324 said: Here's a pic of mine... not sure if it's the same set up.. Thank you sir. That does help. So the foot control on your setup is just a tensioner pulley and not serving as the PTO since you have to engage the PTO with a handle correct? Share this post Link to post Share on other sites
hcminis 1,796 #16 Posted May 11, 2017 This is hoe my drive set up was. I'm missing the foot control arm and pedal. Any help is greatly appreciated 1 Share this post Link to post Share on other sites
WHX?? 58,046 #17 Posted May 11, 2017 I would think you don't even need the pedal since you are running right off the PTO? Not an expert by any stretch but the foot pedal was just for the round hoods? Nice patina BTW 1 Share this post Link to post Share on other sites
Racinbob 13,129 #18 Posted May 11, 2017 Early square hoods still used the pedal like the round hoods. You're right about hcminis not needing it though since he can disengage the pto. 1 Share this post Link to post Share on other sites
oliver2-44 11,731 #19 Posted May 11, 2017 Nice find , double jealous Share this post Link to post Share on other sites
hcminis 1,796 #20 Posted May 12, 2017 I will be installing the sickle bar on my 701. So I need the pedal. Now the task of taking the hack drive pulley extension off. Found thr pedal and other arms needed. Share this post Link to post Share on other sites
Thegearhead0324 1,824 #21 Posted May 12, 2017 To answer your question about my pic, couple reasons I have the pedal with the pto. 1 cuz I wanted the tension on the belt and not try a bunch of belts. 2 it's nice for safety reasons. The pto and pedal have to be engaged. If you can find one it just slides on the shaft and hook a spring to the frame. 1 Share this post Link to post Share on other sites
hcminis 1,796 #22 Posted May 12, 2017 Thank you and great idea. Worked on the front pto drive pulley last night and uncovered a mess. The extension that was added covered up a hacked up drive rod that the bearings and pulleys mount to. Now I have to get help taking that all a part as it is seized on and may nees pressed off. Hoping my brother can fix it for me. Share this post Link to post Share on other sites
