C85 backfires and quits after jump starting?
By
Mr Sweep, in Wheel Horse Electrical
Similar Content
By PWL216
I took off the drive belt today and brought it to Tractor Supply, measured it there and it was 1/2” x 81”. It’s old and stretched out so I bought an 80”. It went on fine but the tractor isn’t shifting into gear properly. Looking here and on the web, it seems the correct part number is 7473 and the size is 5/8”x82”. Is that correct? Maybe the PO had used the wrong size?
By Josh Opitz
I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
By classiccat
New member ...and another old-Iron guy here...with my 1st Wheel Horse tractor.
I was looking for something mainly for pulling an old aluminum boat (18' starcraft) around the property.
Capability to mow and haul yard waste would be a bonus.
2 weeks ago, a C85 showed-up on CL for a song.
He couldn't start it for me and it didn't take me long to figure out why...
This will be a running thread / rolling-restoration as I bring her back to her original, Black-Hood glory!
(DISCLAIMER: I'm an engine-wrencher ...I have the tendency to leave my foot off of the project's gas when the engine starts drinking it!)
By Team70R
Finally got me a lawn ranger and picked it up for an awesome price!! Now to get it running good. H60 Tecumseh won't run right. Goes from running great to running absolutely terrible and backfiring from the carb. I'm guessing the valves are messed up? Compression test rendered around 85 psi.
By JackHorse
Having a hard time justifying $300 to rebuild the spindles and replace pulleys on my deck. The deck is a (i believe) 05-36MS01 on my 1982 C85. I found these kits on Pat's and was wondering if anyone had tried to adapt them to a deck like mine? Thanks
