buffaloman 295 #1 Posted April 30, 2017 Hey guys, My father in law got one of those replacement carburetor off of ebay for the c-160 . I tried to replace it today but the choke cable didn't want to fit into the choke hole. like the holes should've been towards the front of the carb away from the motor instead of to the back towards the motor. I still got it to work ,but the choke works opposite of what its really supposed to , what happened and how can I correct this? thanks . Share this post Link to post Share on other sites
953 nut 62,116 #2 Posted April 30, 2017 The one I bought had two choke shafts with it. Removed two screws, slid the wrong shaft out and replaced it, bolted the plate back in and all is good. 3 Share this post Link to post Share on other sites
buffaloman 295 #3 Posted April 30, 2017 1 hour ago, 953 nut said: The one I bought had two choke shafts with it. Removed two screws, slid the wrong shaft out and replaced it, bolted the plate back in and all is good. yeh unfortunately I didn't get the benefit of a second choke shaft Share this post Link to post Share on other sites
rmaynard 16,567 #4 Posted April 30, 2017 As I have stated in recent inquiries about these aftermarket carburetors, that you should look for a seller who states in his description that he has the correct choke, and that all the screws used in the carburetor are SAE (US). My go-to seller on eBay is "cfamily10". Never been unhappy with his carburetors, and they need no modifications. 7 Share this post Link to post Share on other sites
KC9KAS 4,744 #5 Posted April 30, 2017 I replaced a carb on a WH a few weeks ago that had to have the cable relocated from a top pull to a bottom pull. Had to get a longer choke cable to do the relocate...I will know better next time! Share this post Link to post Share on other sites
pfrederi 18,958 #6 Posted April 30, 2017 I have at least 3 units that have the choke working backwards Put a label on the dashboard and live with it. 2 Share this post Link to post Share on other sites
stevasaurus 23,452 #7 Posted April 30, 2017 You are cracking me up Paul. Reminds me of one of my favorite books..."The Moon is Down". Share this post Link to post Share on other sites
953 nut 62,116 #8 Posted April 30, 2017 17 hours ago, 953 nut said: The one I bought had two choke shafts with it. Removed two screws, slid the wrong shaft out and replaced it, bolted the plate back in and all is good. The Ebay seller I used was eprdistribution and they have you covered for either choke hook up. 1 Share this post Link to post Share on other sites
buffaloman 295 #9 Posted April 30, 2017 9 hours ago, pfrederi said: I have at least 3 units that have the choke working backwards Put a label on the dashboard and live with it. I can live with it on my father in laws wheel horses ,just not mine 1 Share this post Link to post Share on other sites
Mower Man 9 #10 Posted April 30, 2017 (edited) I was wondering if I need a carburetor replacement. I t starts up ok but then it will back fire when I engage the mower belt or shift into second to go forward. It sputters and back fires and usually stops. I then wait a min or less and try to restart it and eventually it will start (5 min) maybe some more back firing and repeat the restart and slowly increase the RPM and then it might work for 30 min or more. Sometimes it backfires under load of tall grass and then I try to restart it. I have dumped the old fuel, replaced the fuel filter, spark plug, cleaned the air filter and put fresh gas into it. I use 100LL Aviation Fuel (no alcohol). I took it to Bechtold Tractor Service in Lodi cleaned and Doug cleaned out the fuel line and removed a couple black pieces of dirt in the carburetor. He charged me 2 hrs labor. I have changed the fuel filter, spark plug and cleaned the air filter. Do I need a new carburetor? The fuel filter is never more than 1/4 full. Could it be the fuel pump? It is a 1998 model 773348. It has 275 hrs on the engine. I would like to get it fixed so that the mower works reliably like it did last year. Thanks for your advise. Rodger Edited April 30, 2017 by Mower Man Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,719 #11 Posted May 1, 2017 Possibly a model 73448? A 314-8 with the Command engine. Garry Share this post Link to post Share on other sites
6bg6ga 272 #12 Posted May 1, 2017 10 hours ago, Mower Man said: I was wondering if I need a carburetor replacement. I t starts up ok but then it will back fire when I engage the mower belt or shift into second to go forward. It sputters and back fires and usually stops. I then wait a min or less and try to restart it and eventually it will start (5 min) maybe some more back firing and repeat the restart and slowly increase the RPM and then it might work for 30 min or more. Sometimes it backfires under load of tall grass and then I try to restart it. I have dumped the old fuel, replaced the fuel filter, spark plug, cleaned the air filter and put fresh gas into it. I use 100LL Aviation Fuel (no alcohol). I took it to Bechtold Tractor Service in Lodi cleaned and Doug cleaned out the fuel line and removed a couple black pieces of dirt in the carburetor. He charged me 2 hrs labor. I have changed the fuel filter, spark plug and cleaned the air filter. Do I need a new carburetor? The fuel filter is never more than 1/4 full. Could it be the fuel pump? It is a 1998 model 773348. It has 275 hrs on the engine. I would like to get it fixed so that the mower works reliably like it did last year. Thanks for your advise. Rodger There is no need for aviation gas period. Find some standard regular without alcohol if you can. Your mixture is lean. Try just a little choke then engage the mower and see if it still stalls out. My guess is it won't. What I would do is look and see if there is an adjustable high speed jet on the carb and if so turn it counter clockwise 1/4 turn and engage the load again and see if it stalls out. If it stalls out turn another 1/4 turn and try it. Note* Most carbs have a low speed idle adjustment mixture control/jet and a high speed one. Its an easy process to find out what you have simply by posting the engine model number, serial and the carb manufacturer. All of this can be looked up. Share this post Link to post Share on other sites
