WHwest8597 85 #1 Posted April 29, 2017 My 1996 314-8 Will not start. Battery is good and checked all the fuses. No power to lights when I turn the key. I can jump from battery to the starter and it fires right up. Share this post Link to post Share on other sites
953 nut 63,020 #2 Posted April 29, 2017 9 minutes ago, WHwest8597 said: Battery is good Famous last words! Take the battery to your favorite auto parts store and have it load tested. Next, clean and tighten all electrical connections including grounds; a little bit of voltage drop at multiple locations could be the cause. Share this post Link to post Share on other sites
SylvanLakeWH 29,827 #3 Posted April 29, 2017 20 minutes ago, 953 nut said: Famous last words! Take the battery to your favorite auto parts store and have it load tested. Next, clean and tighten all electrical connections including grounds; a little bit of voltage drop at multiple locations could be the cause. CHECK THE GROUNDS...same thing happened to me... 1 Share this post Link to post Share on other sites
N3PUY 1,031 #4 Posted April 29, 2017 Ignition switch, safety switch, solenoid. and maybe a fuse or just a poor connection in that circuit. Share this post Link to post Share on other sites
ericj 1,579 #5 Posted April 29, 2017 jiggle the pto lever to make sure the safety switch is making properly eric j 1 Share this post Link to post Share on other sites
