Kavint76 57 #1 Posted April 25, 2017 I got a 1277 with the starter generator on it n when i turn it off it keeps turning engine over till i pull the battery wire off the voltage regulator. Did anyone ever have this prob b4 n how to fix it? I think something in the regulator may b sticking please help. Other than this problem i just got the deck all fixed n running awesome it mows better then any mower i ever owned. Thanks for any help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #2 Posted April 25, 2017 Can't help with your problem but there is a good section in this old Kohler service manual on this system. Section 7.1 to 7.6 Make sure your ignition switch has not failed. Start energized when turned off. The high amperage this system uses is hard on the switches. Garry Share this post Link to post Share on other sites
Ed Kennell 44,732 #3 Posted April 25, 2017 Check the ignition switch. Share this post Link to post Share on other sites
953 nut 64,010 #4 Posted April 25, 2017 Take a look at the two BIG wires on the switch; "B" and "S", they may be touching. Share this post Link to post Share on other sites
Kavint76 57 #5 Posted April 25, 2017 I went out today n it started up fine and shut off fine. the switch is fine no crossed wires. It did it about a month or so ago to. Share this post Link to post Share on other sites
RubyCon1 63 #6 Posted April 26, 2017 @Save Old Iron helped me threw the same issue several years ago. Turns out the cutout relay in the regulator had burned points and was randomly fusing together. Apparently the cutoff relay is meant to open its contacts when the SG produces less then battery voltage so not to allow the connection that charges the battery act to continue to power the SG and jump to the starter mode. File the relay points or replace the regulator. Hope that helps. 1 Share this post Link to post Share on other sites
Kavint76 57 #7 Posted April 26, 2017 Thnx i thought it was in the regulator. Ill check it out n let everyone know what I find out. I wonder if someone on here has a cheap spair they can part with if i cant fix mine. Share this post Link to post Share on other sites
JPWH 6,542 #8 Posted April 26, 2017 You can get one from flea bay for about 30.00. Share this post Link to post Share on other sites
Kavint76 57 #9 Posted April 27, 2017 It was the regulator i took it apart n it was sticking on the one side so i filed both sides n it hasnt done it since. My battery was dead not sure why it may be from the regulator. Thnx everyone 1 Share this post Link to post Share on other sites
