BESTDOGEVER 218 #1 Posted April 25, 2017 Not wanting to destroy a perfectly good block I am going to ask what works to separate the engine halves. I have all the bolts out and it shows no inclination to move in any direction Share this post Link to post Share on other sites
pfrederi 19,783 #2 Posted April 25, 2017 The jugs are glued on and there is also adhesive between the case halves. There are pry points. You really should look at the Magnum twin manual there are warnings about marking things to assure correct reassembly and to avoid scratching mating surfaces. 3 Share this post Link to post Share on other sites
953 nut 63,913 #3 Posted April 25, 2017 There was a thread done a few years ago on Kohler twins. May have some good info in it for you. Please post your progress on here to help build our data base on the twins. 2 Share this post Link to post Share on other sites
BESTDOGEVER 218 #5 Posted May 12, 2017 I finally got a chance to work on this between monsoons it came right apart right now this is the donor engine if the repairs to the original don't work it appears to be a compatible block to transplant the internals from 418 engine in should the jb weld repairs to the block not hold.I am close to the test run on that this weekend. If it holds up I will probably find a way to mothball the spare and keep it for future emergency Many thanks for the input and links to the manual. This is truly the best forum of any sort. Ernie 1 Share this post Link to post Share on other sites
