moper 0 #1 Posted April 17, 2017 I've got a 265-6 I use to clean up around my small farm. Just finished a head gasket, wheel bearings, and charging system fixes on it and I'd like to look into the transmission. Not sure what model it is, or how to service it if needed.Looking to check oil level, drain, and fill with proper oil but I can; find a drain plug, a dip stick, or any way to access the transaxle without removing the seat and fuel tank. Any help is appreciated. Share this post Link to post Share on other sites
rmaynard 16,885 #2 Posted April 17, 2017 I don't think there are many members on here with that model. Seems that I read on another forum that it is technically not serviceable, but some owners have removed the transmission and turned the transmission up-side-down, dumping the fluid out through openings on the top. Then they refilled through the same opening. Doesn't sound like a good way to do it, but I had to do a similar procedure on my John Deere's Tuff Torq transmission. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted April 17, 2017 Here is a service manual for the transmission. You need the 820-Series and you should have a 820-024 model Parts list Garry 1 Share this post Link to post Share on other sites
moper 0 #4 Posted April 18, 2017 Thanks to both of you! Given some of the noises I'm hearing from it the term "not serviceable" may prove problematic...lol. I definitely appreciate the responses. Share this post Link to post Share on other sites
