Jakeshorsetuff 36 #1 Posted April 13, 2017 I have a k301 and when it warms up you go over bumps or shake it ,it sputters but does not stall, and you stop shaking it, it runs great.So I made certain that the throttle does not move when you go over bumps and it doesn't. First I took the head off and there was a lot of carbon build up so i scraped the carbon off with a wooden scraper and i noticed that the piston had a little gap between the block,i don't think that is norma? thanks Share this post Link to post Share on other sites
953 nut 63,105 #2 Posted April 13, 2017 6 minutes ago, Jakeshorsetuff said: piston had a little gap between the block,i don't think that is norma? 7 minutes ago, Jakeshorsetuff said: go over bumps or shake it ,it sputters but does not stall, Could be the carburetor float isn't set right or the baffle gasket isn't in tact. Also, could be a seat switch or PTO switch wire is frayed and grounding out temporarily killing the ignition. 2 Share this post Link to post Share on other sites
joel_400 59 #3 Posted April 13, 2017 I have had similar problems to this before...check for deterioration in your fuel lines. I have had them fall apart inside and plug the inlet @ the carb. Also check your float level in the carb, and for dirt in the bowl of the carb. Maybe this will help. Joel Share this post Link to post Share on other sites
Jakeshorsetuff 36 #4 Posted April 13, 2017 I'll post pics tomorrow and where is the baffle gasket. has no safety switches. I made sure the carb did not have any dirt in it Share this post Link to post Share on other sites
Jakeshorsetuff 36 #6 Posted April 13, 2017 (edited) I put the baffle gasket on and it leaked fuel so I got that to stop leaking but now it leaks out where the baffle gasket is. I tried to post a better pic but the picture has to many MB. The gap between the piston and the block is .020. Jake Edited April 13, 2017 by Jakeshorsetuff Share this post Link to post Share on other sites
953 nut 63,105 #7 Posted April 13, 2017 25 minutes ago, Jakeshorsetuff said: The gap between the piston and the block is .020. Jake It seems to be rebuild time! Share this post Link to post Share on other sites
Jakeshorsetuff 36 #8 Posted April 13, 2017 for real do you think that .020 gap is why it is sputtering Share this post Link to post Share on other sites
953 nut 63,105 #9 Posted April 13, 2017 Maximum out of round is considered to be .002" to .003". Share this post Link to post Share on other sites
Jakeshorsetuff 36 #10 Posted April 14, 2017 thanks for all your help I put the baffle gasket on and no more sputtering. Share this post Link to post Share on other sites
953 nut 63,105 #11 Posted April 15, 2017 1 hour ago, Jakeshorsetuff said: I put the baffle gasket on and no more sputtering. Share this post Link to post Share on other sites
