bluelinehiway 8 #1 Posted April 11, 2017 Have a 1986 310-8 Kohler K241s motor. Spec # 46863 and serial # 1610607383 and I need to replace the starter. Can someone provide the original part number for the starter or a suitable source for a replacement? It's 10 tooth, 7.25" overall length. Having problems finding a replacement that clearly identifies it as a WH OEM replacement. Thanks. Share this post Link to post Share on other sites
rmaynard 16,694 #2 Posted April 11, 2017 No need to specify Wheel Horse. The starter is Kohler specific. The part number is 45-098-09-S. That will fit a K241S, K301S, K321S, and K341S. However, you will be paying an arm and a leg for a genuine Kohler brand starter. Just search eBay or Amazon. Lots of aftermarket ones for a lot less. 3 Share this post Link to post Share on other sites
Achto 30,204 #3 Posted April 11, 2017 38 minutes ago, bluelinehiway said: Can someone provide the original part number for the starter or a suitable source for a replacement? It's 10 tooth, 7.25" overall length. Having problems finding a replacement that clearly identifies it as a WH OEM replacement. Check here http://www.psep.biz/store/kohler_starter_motors.htm. They have aftermarket starters for under $50 3 Share this post Link to post Share on other sites
bluelinehiway 8 #4 Posted April 16, 2017 Thanks for the tips. Bought one off ebay and it seems to work great. Share this post Link to post Share on other sites
