1973 Auto 18 with Ark FEL Moves Pine Tree video!
By
wheelhorse-c-161-1979, in Wheel Horse Tractors
Similar Content
By Goodman
Want to change my 1973 14 hp hydro from 6 volt bat. To 12 volt .what changes are needed
By wheelhorse-c-161-1979
Well my '73 auto 18 was running great yesterday until the engine died and quit. Next I see smoke rising from under the hood. There was short in the wire harness and wire was burned right to the copper. I reached in and was able to stop the tractor from goin up in smoke. I just ripped out the shorted wire harness and it stopped. So i took out the battery and went to work.
I looked at the wiring diagram, which seems straightforward until you try to match it up with the ignition switch.
After spending a couple of hours rewiring, I can not figure out which wire goes where in the ignition.
Can any one help me as I am totally at a loss. The letters on electrical diagram around the ignition sketch don't match anything i see on the actual ignition.
Would anyone be able to give me a hand. I don't need to compound problems by experimenting with wire combinations on the ignition.
Very grateful for any help.
Thank you.
Jack
