seven 202 #1 Posted April 9, 2017 Have a hard time getting it up to full rpm it just seems like it wants to keep dying out got to really feather the throttle to get it up to full rpm. Once it's there then it ok tilled the garden fine but almost impossible to get it up to full throttle? Share this post Link to post Share on other sites
953 nut 66,647 #2 Posted April 9, 2017 Start with a new spark plug (Champion H-10) and a new gas filter and air filter. Share this post Link to post Share on other sites
oldlineman 1,735 #3 Posted April 9, 2017 Maybe some seafome workes for me. Share this post Link to post Share on other sites
WHX?? 56,852 #4 Posted April 10, 2017 What 953 said and go thru the carb. 1 Share this post Link to post Share on other sites
pfrederi 20,676 #5 Posted April 10, 2017 What kind of ignition system do you have?? Electros came with two different ones Breakerless and also a magneto version. (Many Breakerless were replaced with a battery coil system so really you could have any one of the three.) Spark plug gap varies. Mag .025 Battery Breakerless .035 1 Share this post Link to post Share on other sites
seven 202 #6 Posted April 10, 2017 Well just put new plug in it so I wouldn't think that's the problem. It doesn't have a coil on it like my c160 . Somebody mentioned it could be a carb issue maybe like a float that is leaking fuel into it.? Or how hard is it to convert to a coil system. Share this post Link to post Share on other sites
pfrederi 20,676 #7 Posted April 10, 2017 Cleaning the fuel system and carb are important. How did you gap the new plug? .025 or .035 If your plug wire comes out from under the shroud .025 First pic magneto If it comes from a triangular coil .035 second pic breakerless If the breakerless is working why replace it. They are sort of a go/no go thing (assuming plug is gapped and in good shape) Share this post Link to post Share on other sites
seven 202 #8 Posted April 10, 2017 Ok I will try this first ... mine is the top picture Share this post Link to post Share on other sites
