carlosking450 162 #1 Posted April 5, 2017 Good evening friends, I have many doubts about the Kohler k161 engine I am familiar with diesel engines but not with those of gasoline. My K161 I think there is something wrong with the governor, the lever does not back through the action of the dock, it stays in the position that you put it with your hand. Also the disk that has holes is fixed and does not rotate, is it correct? I also think that the previous owner had misplaced the cable accelerator etc. The k161 when I started it stopped I did not keep the gear. I put pictures of the cable placement I had. Share this post Link to post Share on other sites
ol550 879 #2 Posted April 5, 2017 Disc with holes should rotate, cable should be in the lever on the disc not the governor lever. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #3 Posted April 5, 2017 Section 5 is for the governor Garry 1 Share this post Link to post Share on other sites
pfrederi 21,301 #4 Posted April 5, 2017 Your throttle able should connect to the tab I circled 2 Share this post Link to post Share on other sites
wallfish 20,733 #5 Posted April 6, 2017 13 hours ago, carlosking450 said: Good evening friends, I have many doubts about the Kohler k161 engine I am familiar with diesel engines but not with those of gasoline. My K161 I think there is something wrong with the governor, the lever does not back through the action of the dock, it stays in the position that you put it with your hand. Also the disk that has holes is fixed and does not rotate, is it correct? I also think that the previous owner had misplaced the cable accelerator etc. The k161 when I started it stopped I did not keep the gear. I put pictures of the cable placement I had. Looks like the spring for the disc is missing Share this post Link to post Share on other sites
rmaynard 17,642 #6 Posted April 6, 2017 (edited) Here is the way my K161 governor/throttle is connected. Edited April 6, 2017 by rmaynard 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #7 Posted April 6, 2017 He posted photos in this thread Garry Share this post Link to post Share on other sites
carlosking450 162 #8 Posted April 8, 2017 Forgive for not answering or thanking you. I'm going to have to check my governor because the disc is fixed and does not spin. I hope you do not miss any washer or spacer. Is there any manual to disassemble the governor and parts list of the kholer engine? Really thank you very much Share this post Link to post Share on other sites
wallfish 20,733 #9 Posted April 8, 2017 1 hour ago, carlosking450 said: Is there any manual to disassemble the governor and parts list of the kholer engine? Here's the manual Kohler K-Series SM TP-2379 LR.pdf Share this post Link to post Share on other sites
carlosking450 162 #10 Posted April 8, 2017 Thanks a lot tomorrow I'm going to the village, where I have the Kohler, I'll try to see why the disk does not spin, I hope I do not have to disassemble the whole engine. Share this post Link to post Share on other sites
carlosking450 162 #11 Posted April 9, 2017 Hi friends, I finally found the fault, the previous owner misplaced the disk of the governor so that it would remain seized 2 Share this post Link to post Share on other sites
KSU_COWBOY*$ 0 #12 Posted May 11, 2021 Anybody know exactly which hole the pin goes in. Is the function of the throttle bracket to open or close the throttle? Does the Throttle bracket go above or below the pin? If so does it help increase the speed if not, below the pin and help slow the engine down.? This diagram shows the pin in the last hole, mine wasn't that way. Any help is appreciated. Share this post Link to post Share on other sites
