ti-jean 45 #1 Posted April 5, 2017 Hi my battery is full of charge but went Il try to get the engine run at turning the key the engine turn slow 2 or 3 time and wont start same as a empty battery also sound gos clik clik clik . Il suppose that is a starter problem how to check to real cause . thanks 1 Share this post Link to post Share on other sites
prondzy 3,889 #2 Posted April 5, 2017 Buy a new battery 1 Share this post Link to post Share on other sites
ti-jean 45 #3 Posted April 5, 2017 Ok !!! before buying a new battery IL try with a other one . thanks 1 Share this post Link to post Share on other sites
Achto 30,048 #4 Posted April 5, 2017 (edited) If you have a way to check battery voltage, see how far the volts are dropping when you try to start the engine. If they drop below 10v, your battery is probably bad. It could also be a bad connection some place. Clean all of the connections between the battery and the starter ( including any switches & relays )and make sure that they are all tight. Edited April 5, 2017 by Achto 4 Share this post Link to post Share on other sites
953 nut 62,628 #5 Posted April 5, 2017 With any electrical problem you should start by cleaning and tightening all electrical connections including grounds. If this didn't change your results then have the battery load tested. 3 Share this post Link to post Share on other sites
