Huntemcd 239 #1 Posted March 26, 2017 On my raider 8 I have been having to jump it every time. I charged he batter and it started on its own then about a half hour of working it I shut it off then hit the key again and it was dead. My volt meter isn't moving at all. It was just working over the winter. Could the volt meter be bad or could it be the stator. Any ideas would be helpful. Share this post Link to post Share on other sites
jay bee 915 #2 Posted March 26, 2017 Don't overlook the obvious. Check ALL connections first. Jim 1 Share this post Link to post Share on other sites
Huntemcd 239 #3 Posted March 26, 2017 2 minutes ago, jay bee said: Don't overlook the obvious. Check ALL connections first. Jim I have already done that and they are all tight. The ones on the volt meter look a little coroaded would that affect it. 1 Share this post Link to post Share on other sites
Ed Kennell 44,633 #4 Posted March 26, 2017 This may help. 1 Share this post Link to post Share on other sites
Ed Kennell 44,633 #5 Posted March 26, 2017 10 hours ago, Huntemcd said: On my raider 8 I have been having to jump it every time. I charged he batter and it started on its own then about a half hour of working it I shut it off then hit the key again and it was dead. My volt meter isn't moving at all. It was just working over the winter. Could the volt meter be bad or could it be the stator. Any ideas would be helpful. If you down load the above wiring diagram and you have a volt Ohm meter, we can help you locate the problem. 1 Share this post Link to post Share on other sites
pfrederi 19,784 #6 Posted March 26, 2017 You said your Volt meter wasn't moving at all....Your tractor came with an ammeter, was it swapped out?? Share this post Link to post Share on other sites
Huntemcd 239 #7 Posted March 26, 2017 9 minutes ago, pfrederi said: You said your Volt meter wasn't moving at all....Your tractor came with an ammeter, was it swapped out?? Well I just called it a colt meter because I didn't know exactly what it was. I swapped it out about 4 years ago. Some of the connectors on the regulator are melted a little and one on the meter is melted a little. Share this post Link to post Share on other sites
pfrederi 19,784 #8 Posted March 26, 2017 1 minute ago, Huntemcd said: Well I just called it a colt meter because I didn't know exactly what it was. I swapped it out about 4 years ago. Some of the connectors on the regulator are melted a little and one on the meter is melted a little. It is significant to be sure which kind of meter it is as they are wired completely differently. A volt meter would have the needle to the far left when turned off and an ammeter the needle should be in the center when off. Burned terminals on the meter and regulator will cause issues. Do you have a multimeter to do testing with??? 2 Share this post Link to post Share on other sites
Huntemcd 239 #9 Posted March 26, 2017 It is an ammeter then. And yes I do 28 minutes ago, pfrederi said: It is significant to be sure which kind of meter it is as they are wired completely differently. A volt meter would have the needle to the far left when turned off and an ammeter the needle should be in the center when off. Burned terminals on the meter and regulator will cause issues. Do you have a multimeter to do testing with??? Share this post Link to post Share on other sites
pfrederi 19,784 #10 Posted March 26, 2017 Take a voltage reading on you battery engine off should be 12.6 if battery is fully charged Start tractor let it run a couple of minutes take another voltage reading across you battery...Should be around 14v. If not ten shut it down there are three wires on your regulator. One is probably orange and goes to the ignition switch. The other two are probably white and come from the engine. Trace them toward the engine until you find a connector. Unhook it. Set your multimeter to AC voltage and put the probes into the connector on the engine side. start her up and bring her up to at least half 2/3 throttle. Should get and AC voltage reading over 30. If you do then the regulator (or its melted connectors) are the problem. 1 Share this post Link to post Share on other sites
953 nut 63,918 #11 Posted March 26, 2017 Be sure the connections to the regulator are clean and tight. Unbolt it and clean the mounting point to be sure it is well grounded and tighten it well. Your system will work fine without an amp meter; since it is a part of the problem just remove the two wires from it and bolt them together, then tape it up. 2 Share this post Link to post Share on other sites
Huntemcd 239 #12 Posted March 26, 2017 1 hour ago, 953 nut said: Be sure the connections to the regulator are clean and tight. Unbolt it and clean the mounting point to be sure it is well grounded and tighten it well. Your system will work fine without an amp meter; since it is a part of the problem just remove the two wires from it and bolt them together, then tape it up. For some reason now my ammeter is working Share this post Link to post Share on other sites
953 nut 63,918 #13 Posted March 26, 2017 54 minutes ago, Huntemcd said: my ammeter is working Did you clean and tighten the connections? Share this post Link to post Share on other sites
Huntemcd 239 #14 Posted March 26, 2017 7 minutes ago, 953 nut said: Did you clean and tighten the connections? Nope nothing. Just started it and I ran it for about a half hour and it started right back up. I have no clue what was going on. Share this post Link to post Share on other sites
953 nut 63,918 #15 Posted March 26, 2017 1 minute ago, Huntemcd said: have no clue what was going on. That has to be the worst way for a problem to be resolved; never know when it will crop up again and won't know what to do when it happens. Oh well, at least you can go get some seat time. Share this post Link to post Share on other sites
pfrederi 19,784 #16 Posted March 26, 2017 Dirty, loose, burned connections will work sometimes...just not when it is essential. You say the ammeter is working what i sit showing after it has run for a few minutes. Share this post Link to post Share on other sites
