Huntemcd 239 #1 Posted March 26, 2017 My raider 8 with my subsoiler I made. I haven't tried it on my wheel horse. Can't wait to try it out. 6 Share this post Link to post Share on other sites
JC 1965 1,532 #2 Posted March 26, 2017 Should work very well. Thanks for sharing. Share this post Link to post Share on other sites
Huntemcd 239 #3 Posted March 26, 2017 1 hour ago, JC 1965 said: Should work very well. Thanks for sharing. It should work. I have pulled it behind my farmall cub Share this post Link to post Share on other sites
Tankman 3,523 #4 Posted March 26, 2017 Looks great. Does the susoiler tend to dig in deep? Thinking, "Maybe a wheel to set the max depth?" 1 Share this post Link to post Share on other sites
Huntemcd 239 #5 Posted March 26, 2017 18 minutes ago, Tankman said: Looks great. Does the susoiler tend to dig in deep? Thinking, "Maybe a wheel to set the max depth?" It all depends how far forward I have the lever. It should if breaks the plow pan that the plow misses. I had the subsoiler with just one tine going down. Then this winter I added the 2 outer ones. Share this post Link to post Share on other sites
Hacksawhero123 351 #6 Posted March 26, 2017 That's pretty similar to the ripper I built. Mine works pretty well 4 Share this post Link to post Share on other sites
DougC 2,643 #7 Posted March 26, 2017 Looks like both you guys did an excellent job of fabricating. 1 Share this post Link to post Share on other sites
KC9KAS 4,744 #8 Posted March 26, 2017 Nice fab work. It should do a fine job for you! Share this post Link to post Share on other sites
Huntemcd 239 #9 Posted March 26, 2017 2 hours ago, KC9KAS said: Nice fab work. It should do a fine job for you! 4 hours ago, DougC said: Looks like both you guys did an excellent job of fabricating. Thanks. I got to try it out and it did great. Thinking about dualing it up soon 1 Share this post Link to post Share on other sites
pfrederi 18,633 #10 Posted March 26, 2017 (edited) Where are the rocks?? You guys always show this nice dirt...all i have is clay and rocks. Heck my 40hp Case DC3 has to work to pull a 2 bottom plow. Kid next door was discing a field with a big disk and 140hp JD tractor. the screeching noises of the discs on the rocks was painful to hear. There is another thread about pulling a plugger. i brought one up here with me from VA when I retired. Used it once never got in more than inch or two, with cement blocks on it. too many rocks Edited March 26, 2017 by pfrederi 2 Share this post Link to post Share on other sites
can whlvr 994 #11 Posted March 27, 2017 nice job on the subsoiler,and pfed is correct about the soil here too,a horse would never pull 2 unalone 3 rippers,but we have lots of clay and rocks,heck my full size skid steer has trouble with the post hole digger lots of the time 1 Share this post Link to post Share on other sites
Duramax7man7 506 #12 Posted March 29, 2017 @Hacksawhero123 Can we see more detailed photos of your lift piston? That looks interesting. Share this post Link to post Share on other sites
Hacksawhero123 351 #13 Posted April 7, 2017 Mastiffman, the hitch lift uses a duplicate of the deck lift cylinder mounted almost vertical. I stacked an extra spool valve to operate independently. Fabbed up a bracket to mount to the four bolts on top of the axle 1 Share this post Link to post Share on other sites
Hacksawhero123 351 #14 Posted April 7, 2017 Oh, and if anyone knows where I can find a valve block with the float detent, I'm looking for one. Thanx! Mark. 1 Share this post Link to post Share on other sites
Duramax7man7 506 #15 Posted April 7, 2017 Very nice! I like it! You can really force it into the ground! Share this post Link to post Share on other sites
R. L. Addison 299 #16 Posted April 7, 2017 Someone had a Sears loader parts list with valve part#'s, I'm going to try tyhat soon as I can. Share this post Link to post Share on other sites
