jhunsch 20 #1 Posted March 25, 2017 Need some help finding a fuel pump kit for Kohler M12 K301 fuel pump. Standard black plastic pump. Any help will be greatly appreciated. 1 Share this post Link to post Share on other sites
Achto 30,810 #2 Posted March 25, 2017 Check this site, they have complete pumps for around $35. http://www.psep.biz/store/kohler_fuel_pumps.htm 2 Share this post Link to post Share on other sites
skrusins 128 #3 Posted March 25, 2017 Bought several kits from this guy. http://www.then-now-auto.com/fuel-pumps/ Share this post Link to post Share on other sites
jhunsch 20 #4 Posted March 25, 2017 Thank you Sir. Any leads to just getting the two check valves. Share this post Link to post Share on other sites
Achto 30,810 #5 Posted March 25, 2017 11 minutes ago, skrusins said: Bought several kits from this guy. http://www.then-now-auto.com/fuel-pumps/ I had checked this site but this line from the site should be noted. Please note that our valves WILL NOT fit securely in the “plastic pumps”. Just a heads up. 2 Share this post Link to post Share on other sites
Shynon 7,533 #6 Posted March 26, 2017 14 hours ago, jhunsch said: Standard black plastic pump. Plastic pumps are not rebuildable 14 hours ago, achto said: I had checked this site but this line from the site should be noted. Please note that our valves WILL NOT fit securely in the “plastic pumps”. Just a heads up. 1 Share this post Link to post Share on other sites
953 nut 63,911 #7 Posted March 26, 2017 You can pick up an electric low pressure fuel pump on for about $ 10 shipped, they work fine. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted March 30, 2017 I like the electric ones especially if you don't start the tractor often,much easier on the starter because you turn on the key and wait a few seconds and the pump fills the carb 1 Share this post Link to post Share on other sites
