Countdown To Christmas!
HamptonT
How do you sharpen deck blades?
HamptonT
Just wondering how it should be done. I've always ground them on my bench grinder.
rjg854
That's one way ;) I tend to sharpen mine by hand with a file, but then I'm old school :laughing-rofl: I just feel I don't use up as much blade just sharpening them.
  • Like 4
Jeff R.
I have been using the 4 1/2" angle grinder lately and this is my new preferred method.
  • Like 4
pfrederi
Flap wheel on an angle grinder
Ed Kennell
I use the bench grinder and a bucket of cooling water.  Then dress and deburr with a 12" half  round bastard file.
DennisThornton
4 1/2 grinders with different grits. Faster & better than anything else I've tried.
slim67
:text-yeahthat: I use a Zirconia Z80flap disc on my grinder at work and home. I think thats the easiest way.
Sarge
Ceramic flap disks on the 4-1/2" Metabo - goes quickly and the ceramic doesn't create nearly as much heat . If you decide to try these wheels do not use a lot of down pressure or you'll burn it and they won't cut . Best performance I've found so far is from CGW (Camel Grinding Wheels) . For polishing/cleaning they now make a non-woven surface conditioning flap disks in 3 grades - love those things !
Sarge
WHX??
4.5 grinder with a basic wheel, may have to give the flap wheel a try sometime. Make sure you balance.
DennisThornton
If the blades are rough I get aggressive with a very coarse hard wheel but never enough to heat the blade edges to any color.  Then usually a 120 grit flap disc to touch up the cutting edge.  Love the flap discs!  And I'm quite the fan of a fine double cut file to finish if I'm showing off.  That sharp edge will last and last for about 10 minutes around here!  Sand & rocks! I've got to set up two mowers.  One for the lawn around the house and another for the trails & less groomed areas.
T McCool
Angle grinder/flap wheel. Hasn't failed me yet😉
can whlvr
angle grinder and don't even them off,ive done it so often they rarely go out of balance
