goblbustr 9 #1 Posted March 18, 2017 well my c-160 and snow blower tore up 2 feet of snow with 4 foot drifts no problem in the recent nor easter here in Pa. However just as I was finishing up smoke started rolling out from under the steering wheel. A little investigating found the wire leading to the tail light shorted out and fried my wireing harness and possibly the switch. So does anyone know where I can get a harness for a 75 C160 and a part # for the switch would help. Thanks in advance Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,007 #2 Posted March 18, 2017 You can download the operator manual that has a wiring diagram from here There is not much wiring in this model. The terminals can be removed from their plastic holder so wire and terminal replacement is fairly simple. If you don't know how to do that we can explain it. If you can solder the connections even better. Toro wants $20 for a switch you can get locally for less than $5. Garry 4 Share this post Link to post Share on other sites
