Red144runner 658 #1 Posted March 14, 2017 When turning the input pulley by hand and the motion lever in forward or reverse shouldn't axles move? Oil is full and clean. Share this post Link to post Share on other sites
Ed Kennell 43,843 #2 Posted March 14, 2017 You would have to have the pump up to some minimum RPM to build enough pressure to turn the wheels. I am not sure what that minimum is. I test non running hydro tractors by chaining them to a tree and driving the hydro with a long belt and a running tractor positioned behind the non runner. 4 Share this post Link to post Share on other sites
smoreau 658 #3 Posted March 14, 2017 With the tractor off the ground on jack stands or the wheels off you can put a socket on a clutched drill ( not a impact!!!!!) and turn the pulley to charge the pump and test its operation. Once it is charged you can move the pump pulley by hand and get a reaction out of it. Put the drill in reverse for the correct direction. 4 Share this post Link to post Share on other sites
Red144runner 658 #4 Posted March 21, 2017 Great info. My dealer confirmed the info here. Seems input rpm has to be around 700 minimum 3 Share this post Link to post Share on other sites
squonk 44,922 #5 Posted March 21, 2017 16 hours ago, Red144runner said: Great info. My dealer confirmed the info here. Seems input rpm has to be around 700 minimum Have a couple of cups of Starbucks and you won't need the drill. 1 Share this post Link to post Share on other sites
