carlosking450 161 #1 Posted March 10, 2017 Good night from Spain friends, I continue with the restoration of my wheel horse 702, my motor does not have a nameplate and I do not know if it is a k141 or k91 since I have read the manual and all K models except the 91 Mechanical pump, mine is by vacuum. Another fact is that my valves do not have any screws to regulate the clearance, how should I solve it by grinding and, if necessary, replacing valves? Finally my carburetor is a Carter model N and number 3408S. Thanks Share this post Link to post Share on other sites
Racinbob 12,644 #2 Posted March 10, 2017 Your 702 originally had a 7hp K-161 on it. The K-91 is a 4hp and the K-141 is a 6hp. Many of them had vacuum fuel pumps. 1 Share this post Link to post Share on other sites
953 nut 63,911 #3 Posted March 10, 2017 This manual from Kohler will give you the information you need. Kohler Single Cylinder Engine Specs _ Torque Values and Sequences for Fasteners _ Identification & Torque Settings of Most Commonly Used Grades of Bolts (1).htmlKohler K91 K161 K181 OM #ENS-593-F HR.pdf 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #4 Posted March 10, 2017 Carlos, didn't we already determined here... ...you're 702's engine is a 7hp, Kohler K-161? Share this post Link to post Share on other sites
carlosking450 161 #5 Posted March 12, 2017 Hola de nuevo He estado limpiando las válvulas y he visto que se picoteaban me puede decir si las válvulas son todos iguales? Me refiero a las de los K161, si tienen o no la regulación? Donde se podía comprar a buen precio las dos válvulas con guías y asientos? Gracias por todas sus respuestas Share this post Link to post Share on other sites
AMC RULES 37,254 #6 Posted March 12, 2017 Translation... Hi again, I've been cleaning the valves and I've seen them pecking could you tell me if the valves are all the same? I mean those of the K161, whether or not they have regulation? Where could the two valves with guides and seats be bought at a good price? Thank you for all your replies Share this post Link to post Share on other sites
