Rkellet 0 #1 Posted March 1, 2017 First I. Ran the fluid empty while plowing put 2 qtr auto trans fluid now it only moves forward and reverse for about a total of 3 ft Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #2 Posted March 1, 2017 15 minutes ago, Rkellet said: First I. Ran the fluid empty while plowing put 2 qtr auto trans fluid now it only moves forward and reverse for about a total of 3 ft what trsans is in it? is it a hydro if its a hydro you need to jack it up and purge it because air got in the system. should show procedure in manual. 1 Share this post Link to post Share on other sites
pfrederi 19,198 #3 Posted March 1, 2017 I assume there was ATF in there previously...That would most likely make this a Sundstrand. with a hydro lift it needs 5 qts Share this post Link to post Share on other sites
Rkellet 0 #4 Posted March 2, 2017 8 hours ago, craftsmanmowerfreak said: what trsans is in it? is it a hydro if its a hydro you need to jack it up and purge it because air got in the system. should show procedure in manual. I don't have a manual on it and yes it is hydro Share this post Link to post Share on other sites
953 nut 62,913 #5 Posted March 2, 2017 If you go to the "Manuals" section on this site you can download your manual. 1 Share this post Link to post Share on other sites
pfrederi 19,198 #6 Posted March 2, 2017 You could get more help if you told us what model tractor you were dealing with, Not all hydros need priming Share this post Link to post Share on other sites
Rkellet 0 #7 Posted March 2, 2017 It is a d180 sorry I did not include Share this post Link to post Share on other sites
pfrederi 19,198 #8 Posted March 2, 2017 First off most D series used 10w-30 oil for the transmission are you sure ATF was what was in it??? ATF and motor oil do not mix well. Share this post Link to post Share on other sites
Rkellet 0 #9 Posted March 3, 2017 18 minutes ago, pfrederi said: First off most D series used 10w-30 oil for the transmission are you sure ATF was what was in it??? ATF and motor oil do not mix well. Not sure what was in it I was told by a friend he thought tag the pump works feels like diff locks up after moving forward and reverse for about 3 feet. Did the same thing before adding fluid I am very new to the Wheel Horse but do have some mechanical ability thanks Sorry atf Share this post Link to post Share on other sites
pfrederi 19,198 #10 Posted March 3, 2017 Release the tow valve and try pushing her a good distance. Does it still lock up? D series had issues with the bolts that hold the differential together failing then getting jammed between the differential bull gear and the case.. If it locks up do not use excessive force you can crack the transaxle case. If it did lock up while pushing you will probably hae to remove the transaxle and split the case.. You should download the sundstrand manual. http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/ 1 Share this post Link to post Share on other sites
Rkellet 0 #11 Posted March 3, 2017 9 hours ago, pfrederi said: Release the tow valve and try pushing her a good distance. Does it still lock up? D series had issues with the bolts that hold the differential together failing then getting jammed between the differential bull gear and the case.. If it locks up do not use excessive force you can crack the transaxle case. If it did lock up while pushing you will probably hae to remove the transaxle and split the case.. You should download the sundstrand manual. http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/ Was going to do that but waiting for warmer weather thank you Share this post Link to post Share on other sites
