classicdmax 190 #1 Posted February 26, 2017 I'm replacing ignition cool today for the hell of it. Had to take it off anyways to get at the carb for maintenance. Stamped on the new coil indicates "do not use with external resistor". can anyone please advise me how to move forward? Isn't the resistor necessary for points type ignitions? thanks Share this post Link to post Share on other sites
rmaynard 16,843 #2 Posted February 26, 2017 Coils for that engine have an internal resistor. No need for an external one. The correct coil is a Kohler 41 519 21-S or equivilent. 1 Share this post Link to post Share on other sites
classicdmax 190 #3 Posted February 26, 2017 So the external resistor currently in place was prob used due to type of coil used by prior owner? Share this post Link to post Share on other sites
Ed Kennell 44,723 #4 Posted February 26, 2017 Are you confusing the condenser with an external resistor? 2 Share this post Link to post Share on other sites
classicdmax 190 #5 Posted February 26, 2017 Ah, yes. Apologies. so I should be able to install without issues then? Share this post Link to post Share on other sites
Ed Kennell 44,723 #6 Posted February 26, 2017 Yes, if you have the correct coil as Bob listed. Connect ignition switch to + coil post and points and condenser to -coil post. 3 Share this post Link to post Share on other sites
classicdmax 190 #7 Posted February 26, 2017 Thanks guys Share this post Link to post Share on other sites
squonk 45,408 #8 Posted February 26, 2017 Napa Coil # IC64SB 2 Share this post Link to post Share on other sites
