C-121uk 183 #1 Posted February 21, 2017 My RJ 58 didn't come with a gas tank, will a tank off a K141 engine fit in the brackets on an RJ hood, i've always thought a k91 tank is smaller but my eyes could be deceiving me Thanks Share this post Link to post Share on other sites
953 nut 64,172 #2 Posted February 21, 2017 I think that the K91 tank is a smaller diameter. If you are going for total originality the answer is no; if you are looking functionality you can just adapt the mounting straps and use it. 1 Share this post Link to post Share on other sites
C-121uk 183 #3 Posted February 22, 2017 10 hours ago, 953 nut said: I think that the K91 tank is a smaller diameter. If you are going for total originality the answer is no; if you are looking functionality you can just adapt the mounting straps and use it. Thanks, I thought they looked a little smaller, i'll have to have a look and see what modifications might have to be made 1 Share this post Link to post Share on other sites
RJcollector 56 #4 Posted March 14, 2017 (edited) There is a tank off a suburban on ebay which I believe is the same as an RJ. Ive seen them come up on ebay once in a while. Good Luck Edited March 14, 2017 by kfx400 Share this post Link to post Share on other sites
wallfish 19,333 #5 Posted March 14, 2017 Suburban tanks are the same size but not the same as far as filler neck location. The RJ tank's neck is closer to the edge and the mounting straps on the hood match with that. Think the fuel outlet is also in a different location. Suburban straps match their respective style tank. Subtle differences but they are different. On 2/22/2017 at 5:18 AM, C-121uk said: Thanks, I thought they looked a little smaller, i'll have to have a look and see what modifications might have to be made A K91 tank is quite a bit smaller, about 1/3 the capacity. But a K91 doesn't drink fast so they can certainly be used. 1 Share this post Link to post Share on other sites
RJcollector 56 #6 Posted March 14, 2017 @wallfish I didn't know that about the tanks. Thanks for the info Share this post Link to post Share on other sites
wallfish 19,333 #7 Posted March 14, 2017 No Problem Once you own a few and try to swap parts and/or find those parts, you tend to notice the small differences. It doesn't take much to get a Suburban tank to fit a RJ, especially if the straps were broken off since they can easily be re positioned. The back strap barely hangs on to the rear of the tank when it's attached to the hood in the original position. 2 Share this post Link to post Share on other sites
C-121uk 183 #8 Posted March 14, 2017 6 hours ago, wallfish said: Suburban tanks are the same size but not the same as far as filler neck location. The RJ tank's neck is closer to the edge and the mounting straps on the hood match with that. Think the fuel outlet is also in a different location. Suburban straps match their respective style tank. Subtle differences but they are different. A K91 tank is quite a bit smaller, about 1/3 the capacity. But a K91 doesn't drink fast so they can certainly be used. Thanks, I thought they were smaller, my hood doesn't have the mounting straps so we'll be fabricating some new ones, my clinton engine i sourced for my RJ came with a small tank and if thats salvageable then we'll be making that fit. Thanks for your help Share this post Link to post Share on other sites
